68 wire harness advice
Old Apr 25, 2005 | 12:50 AM
Daniels's Avatar
Daniels
Default 68 wire harness advice
Hi Guys,
I started today putting the 68 427 convertible back together after receiving it back from the paintshop last week. I bought all the wire harnesses new since the original ones were totally messed up. I somehow missed the power window harness and would like to purchase it ASAP.
Question: there is a power window harness for $143 at corvette central part Nr. 663115 . i Question next to the price it says each!
does it mean 1 need 2 of those? Are those harnesses just plug and go?
I got the power window connectors from the motor to the harness plug, a black and yellow wire. Is this power window harness just a connector from the motors to the switches and the power lines?
The wiring diagramm on my assembly manual does not show anything about the power window lines. Does anyone have such a Diagram which could share over the net?
Thanks a lot,
Dan
Old Apr 25, 2005 | 08:01 AM
markdtn's Avatar
markdtn
You just need 1 P/W harness.
I don't have a diagram handy, sorry. It has a relay under dash, goes out to each window, and has the switches in the console. I think there is only 1 power wire and a ground to hook up.
I buy my harnesses from The Last Detail in Atlanta, GA. Best prices I have found on Lectric Limited harnesses.
Old Apr 25, 2005 | 01:25 PM
vetsvette2002's Avatar
vetsvette2002
Veteran: Marine Corps
St. Jude Donor '13-'14-'15-'16
Originally Posted by Daniels
Hi Guys,
Thanks a lot,
Dan
Dan,
I offer full color wiring diagrams for Corvettes from 1953 through 1979. They are about 22x34" and include ALL electrical diagrams even the options. Alos included are the fuse/circuit breakers, lamps, and a vacuum diagram for the lamps, heater-a/c and wipers.
Don
Don
Old Apr 28, 2005 | 04:17 PM
lobo2001's Avatar
lobo2001
Default Console
I need the diagram (picture) of the back of console showing how the wires hook up. A picture's worth a thousand words!!
Old Apr 28, 2005 | 04:33 PM
ksbunting's Avatar
ksbunting
Dan,
I purchased the wiring diagram that Don (Vetsvette2002) is referring to and I have to say it is a piece that is worth framing and putting on the wall. It is in color and is laminated and worth getting. Disclaimer: I don't know Don, have no interest financial or otherwise in his company. Just a satisfied customer. Used it for my 68 restoration.
Kurt Bunting
Massachusetts
Old Apr 28, 2005 | 10:30 PM
timrb73coupe's Avatar
timrb73coupe
i got one for my '73 ... top caliber workmanship
To 68 wire harness advice
