Wrong bolt size for rear spring?
Old May 24, 2005 | 09:22 PM
SkunkApe's Avatar
SkunkApe
Default Wrong bolt size for rear spring?
Based on the advice of a recent post, I went ahead and purchased (locally) two 8" x 9/16" Grade 8 bolts in order to lower my rear-end.
Crawling underneath today, I noticed the original bolts (appx. 6") are MUCH thinner...either 1/2" or 7/16". Now I suspect the person offering the advice doesn't know how to measure bolts and thought that 9/16" was the size of the wrench used...(I believe which would make the bolt 1/2").
So...what is the REAL size of the rear sping bolts?
Note to backyard mechanics: Bolts are measured by the size of their shaft & threads, not the size of their head or the size wrench used
Old May 24, 2005 | 09:26 PM
lostpatrolman's Avatar
lostpatrolman
Why dont you crawl back under the car and measure them?
Old May 24, 2005 | 09:58 PM
redvetracr's Avatar
redvetracr
I think the "factory bolts" are cut down in the middle and they are in reality a 9/16 bolt....i run 5/8 bolts on my racer.
...redvetracr
PS: a 3/8 bolt takes a 9/16 wrench...
Old May 24, 2005 | 09:59 PM
fl_rider's Avatar
fl_rider
Default Just changed mine
I just removed 2 9/16 x 6 bolts and replaced them with 2 9/16 x 8 bolts.
The bolt head is 13/16" and the nut is 7/8".
It dont get any simpler than that
Maybe yours has been bubba'd
Old May 24, 2005 | 10:03 PM
SkunkApe's Avatar
SkunkApe
That describes the new bolts I have. But the factory(?) bolts are definitely thinner.
Why don't I crawl underneath and measure? Because I'll still need to know the correct size bolt.
Old May 25, 2005 | 11:32 AM
BigBlockk's Avatar
BigBlockk
Well then you have your measurement. The factory bolt plus a couple inches more length. Ya know Ecklers sells the bolt you're looking for. Ya don't gotta measure anything. Here is the link.
http://www.ecklers.com/product.asp?d...PTK84EFM293EAC
BigBlockk
Later.....
Old May 25, 2005 | 04:12 PM
redvetracr's Avatar
redvetracr
In that case GO FISH!!
Old May 25, 2005 | 04:30 PM
skydaddy's Avatar
skydaddy
QUOTE: I just removed 2 9/16 x 6 bolts and replaced them with 2 9/16 x 8 bolts. The bolt head is 13/16" and the nut is 7/8". It dont get any simpler than that
Old May 25, 2005 | 08:26 PM
SkunkApe's Avatar
SkunkApe
Ding, ding ding! We have a winner. Climbed underneath and measured the bolts. While the shaft is 1/2", the threaded part is 9/16". Apparently the bolts have been "necked down" from the factory.
Go figure...
I checked with VB&P. The bushings for their extended bolts measure 9/16".
To Wrong bolt size for rear spring?
