I bought the entire suspension rebuild kit from Mid America. My car never had a rear sway bar in it when I got it and when I tried to install the rear sway bar everything fits in place, but there is not enough room to bolt it on let alone get any type of tool in there to tighten it up. I considered welding it on, but my friends don’t think that is a good idea have any of you run into anything like this? If so what did you do?
I'm confused ... weld? Are you referring to the clamps that attach the bar under each frame rail or the ends that attach at the trailing arm?
My sway bar didn't fit on when i tried to install it. The attachment bars were not long enough. I had bought the street slolam kit from VB&P and i was pissed. I had subsituted stiff springs and it actually pushed or held the trailing arms farther from the frame rail.
I sent them a nasty letter about selling stuff that doesn't work and how they should include this simple fix in the kit. This was in the 80's
I bought mild steel 2 X 1 heavy wall cut to about 4 inches. I drilled two holes and spaced my 3/4 rear bar down. I originally installed 2 X 2 bar stock. It made the sway bar nearly parrallel to the ground.
Sounds like this is different than gkulls issue. Is there enough vertical space between the sway bar ends & the trailing arm mounting plate to insert the attachment rod & bushings? If not, you may need to lift the body slightly up off the suspension to make additional room to fit it in. Also, make sure the bar is in right side up .... the bend in the middle faces up.
My u brackets were bolted on with tapped bar stock.
There aren't any nuts underneath just this bar. No tools needed.
Pretty sure this thing is in the way for working on the spring bolt. If you weld it on
Something is wrong with that setup. Either its a year change or you got the wrong bar. Or you don't have the right attachment parts.
Mine has holes for a horizontal bolt. This bolts not to the trailing arm but a bracket. This bracket then bolts to the U-shaped bracket on the trailing arm. This might be why gkulls was too short. Theres spoda be more stuff on the end of the bar.
The bar doesn't bolt straight to the arm.
GearheadZ - Boy that looks so pretty that I'd be afraid to drive it and get it dirty!
You see in your picture #2 how the bar is putting a crimp in your rubber bushing. Spacing the bar down like I did corrects that problem. It frees up the binding.
Gkull ... Thanks it's been a LONG project .... body off, replaced both frame rails, body strip & paint, replaced entire rear suspension, you name it ... just waiting for some trim parts to come back from the chromer & she'll be back on the road .... no rain driving or off roading for me!
Good point on the horizontal angle of the bar. The car sits a little high now so that's contributing to the binding. When I get the stance lower where I want it, I'll probably make a spacer to get it horizontal. Thanks again!
...just waiting for some trim parts to come back from the chromer & she'll be back on the road .... no rain driving or off roading for me!
Mark
I hear that ... very close to driving again, too (3+ years).
Once the body is back on, the rear end should come down significantly.
my sway bar should be stock specification, as far as I know that’s what I have but no matter what there is not enough room to bolt it on. I tried taking all the weight off the suspension all that does is make the linkage arch a little. And still no luck
I have just purchased a rear (and front) sway bay for my '70.
The brackets I have appear similar to the above image however I do not have mounting holes in the arm - just the bigger hole to access the spring bush/bolt.
From what I can determine from this image, the new plates are bolted to the arm - one bolt through the existing larger hole, HOWEVER it appears as if the other bolt is external to the arm (not bolted through it. Is this correct? Or will I have to drill new holes either side of the larger holes?
If anyone is interested I have an extra genuine GM factory 9/16 BB rear bar (just like this one) available with mounting hardware, minus the 4 bushings marked #1...send a PM.
This OEM bar offered is the ONE to have with the OEM endlinks. Aftermarket bars with the horizontal endlinks restrict the movement of the IRS to a much greater effect than the OEM type bars and can cause unexpected oversteer to the unaware. I replaced my OEM 7/16 rear bar with a 3/4 OEM type bar to match the front 1 1/8 inch OEM bar-everything has poly bushings-everything! GM did not use the same endlink format on the rear bars as the front bars for a very good reason the C3 rear IRS. The horizontal endlinks for rear sway bars are fine on solid axle cars. Hope that helps!
Thanks for the feedback - appreciate the information provided.
As I already have the bar with horizontal endlinks I'll continue with its installation. And "oversteer" - love it!! Brings out the best in my driving :-)
