Where to grease a fuel pump??
I'm in the process of fitting a new mechanical fuel pump on my 1980 C3. The new pump instructions says to grease the rocker arm and rocker cavity to lubricate internal parts. Now does that mean the cavity on the fuel pump or the cavity on the engine block or both??
I know someone had done this recently so any help would be appreciated!!
I would not recommend using any lube on the fuel pump parts due to the fact that that area is part of the oil system and will get soaked with engine oil, and wash lumps of lube into the oil pan and contaminate the oil. Therefore, I recommend that you apply some of engine oil...whatever you are running in the engine...on the upper portion of the push rod in the area where it will be going through the block, and a drop on the both ends. You don't need to worry about anything else because about 30 seconds after you start the car there will be a nice flow of oil through there. If you put too much on the push rod then it will drip down onto your gasket surfaces before you can get it bolted up. Another tip is to remove the bolt on the front of the engine near the fuel pump...you will see that it isn't holding anything on...it's an access port so you can get in there with something...finger...whatever...and hold the push rod in place while you set the pump in place.
Cheers guys,
I actually managed to get the fuel pump all installed successfully and I no longer have a fuel leak!
When I installed it I greased the rod to keep it in place, I plan to change the oil in a few miles so the grease in the oil shouldn't be too much of a problem. I also greased the pivot lever and tip of the lever on the fuel pump. I didn't put any grease in the fuel pump itself. I assuming that oil from the engine will flow into here and lubricate the internals of the pump - is that a fair assumption or am I risking the pump mailfunctioning?
Thanks again!
Thanks again!
Originally Posted by more_cc's
Cheers guys,
Thanks again!
Thanks again!
Guys I have a 1979 l48 is it the same as mentioned above, does oil flow in the chamber where the push rod is? thanks
St. Jude Donor '09
