I am working on a 1982 with the little bolts that hold the u joint retaining strap to the yokes. On this vette, the bolt is a small metric inverted hex head type bolt. The problem is that you can easily strip the edges off of the inverted hex head if you use a 12 point 5/16 socket.
But if you want to solve the problem, you can change them to a conventional 6 pt hex headed bolt. I was looking thru the GM parts inventory today and found the hex head replacement. The GM part number is 12338087. They come 10 to a package and cost just over a $1 a piece.
So if you are having a problem, this might be your cure. I am not sure if any other year vettes use this small inverted hex bolt. But the 82 in my shop sure does.
Ed
I ran in to that same problem this past weekend on my 82. I used a 1/4" 12 point boxed in wrench to remove them. As my luck would have it, I got three off with no problems, the fourth was already stripped..I neded up taking it off with a pair of vice grips.
The bolt thread pattern is 1/4" - 28, I went to autozone and they sell "U-joint repair kits", but the kit for my vette didn't have the same bolt size and thread pitch I needed for some reason. I ended up getting a kit made for a chrysler......which had the 1/4-28" bolt with the 6 point hex head. The kits are about 3 bux for one u-joint strap (2 bolts). It worked fine for me.
Those shields are a PITA.....if someone wants some, I'm not using mine. they're in perfect condition but only work on a stock trailing arm and not on my home built stuff.
As for the strap bolts, they're not metric, they're 1/4-28 UNF thread. I have NAS quality 12 points on all those places, works much better than the stock stuff.
My 81 has 12 point screws on the half shaft u-joint retainers and my 82 (as well as my previous 82) had torx heads. If I remember corectly it was a T-10. The torx heads are a real pain because at that size most tool manufactures go to a larger diameter socket size (3/8") which make it so big it can't sit square on the bolt head.
I found the same "help" packages for a jeep that had the same size u-joint bolts.
