Engine Won't Stay On (Help)
Old Oct 13, 2005 | 09:19 PM
enkeivette's Avatar
enkeivette
Default Engine Won't Stay On (Help)
Hi guys, I just dropped in a 383 and everything was working fine on Monday. The engine fired right up after a few trys and I let the cam break in between 2K and 2.5K RPM for about 20 minutes. I even drove it around the block, but the timing was obviously off. The car wouldn't idle by itself and the carb backfired.
Anyways since that day I haven't been able to get the engine to run for more than about 10 seconds. I don't know what happened. I pull the throttle and fuel is squirting in there so I'm lost. Today I pulled off the dist cap with the line on the damper at 0 and checked the rotor positioning. I moved it about 1/4 of an inch but it didn't help. On my last attempt the carb backfired and caught fire. What the hell is wrong?
(Also FYI the carb is the stock 750cfm Q-Jet with the emissions hoses plugged off. Also the thermostatic coil choke doesn't hook up to the new manifold)
Old Oct 13, 2005 | 09:35 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
almost sounds like its not getting enough fuel....disconnect the fuel line at the carb and crank the engine and see how much fuel your are pumping out.
Old Oct 13, 2005 | 09:40 PM
big_G's Avatar
big_G
Maybe no gas in the tank? Don't laugh..It happens more than it should.
Old Oct 13, 2005 | 11:21 PM
majic1984's Avatar
majic1984
Haha.. you're not joking dude!! One day I was trying to crank mine up after I had filled the tank within the same week (I don't drive it a lot) and it just wouldn't crank! So I looked around for awhile.. tried re-adjusting my carb, turned the key, and nothing.. so then I go back to my tank and see no gas - apparently there was a pinhole leak in the tank and it was bone dry!
Old Oct 14, 2005 | 12:03 AM
enkeivette's Avatar
enkeivette
I'll try pouring 5 gallons in tomorrow, it is on empty but I see squirts of fuel so I doubt that that's it. Anyways, I'll let you guys know tomorrow.
By the way does TwinTurbo post here?
Old Oct 14, 2005 | 12:07 AM
bobs77vet's Avatar
bobs77vet
yes twin turbo posts here....it may not be the tank that is failing .....i would be looking at the fuel pump......i have theory that says that when the old fuel pump is removed and the arm fully releases it tears the membrane for the pump.....you install it and it does not work properly....it gives you some flow just enough to screw with you as it craps out.....happened to me and alot of other guys, you would be surprised.
Old Oct 14, 2005 | 02:14 AM
enkeivette's Avatar
enkeivette
It is a brand new fuel pump, but that's a very interesting theory.
I had to remove the base of the pump and rotate it so that the outlet would clear the frame rail. Do you think I could have messed something up? There was a gasket that is incorporated into the pump that didn't fit as nicely after I rotated it. And the car did run for twenty minutes on Monday just as it is now so...
Old Oct 14, 2005 | 06:32 PM
blue427's Avatar
blue427
if it's a holly adjustible pump it's really not meant to be adjusted more than 90 degrees ,wouldn't work on my 69
Old Oct 14, 2005 | 07:16 PM
bobs77vet's Avatar
bobs77vet
interesting??? i don't know the pump you are using but i would be suspicious of it
Old Oct 14, 2005 | 08:35 PM
Jay M's Avatar
Jay M
I made the mistake of not driving the Vette all week, well she was mad at me this moring and need some special time, just me and her before work.
She started up ok, I let her get all warmed up, and then I took my foot off the gas pedal and she wanted to stall. I thought maybe she needed to be driven a bit then she'll settle down. At the bottom of the driveway she stalled and refused to start. I persisted to the point at which I ran the battery out.
So at 8am I'm dresses for work and need to hook up the batterey charger and get her running well enough to at least get her out of the street.
The problem was a sticking needle valve in the carb. I just twisted it a bit to loosen anything and free what ever was causing it to stick.
After that she ran great and I took her to work with me.
~Jay
Old Oct 14, 2005 | 09:47 PM
enkeivette's Avatar
enkeivette
Talked to a friend who suggested I do the following: Rotate the dist counterclockwise about 1/4 of an inch, close the choke, and let out the idle mixture screws a bit.
It fired right up, damn is that a lopey cam! It won't idle below about 800 or 900 rpms and right there the timing is set at 7.5BTDC.
It obviously needs a professional tune but right now it is definitely driveable.
Old Oct 14, 2005 | 09:49 PM
bobs77vet's Avatar
bobs77vet
....It fired right up, damn is that a lopey cam! ...
good job, you would be surprised how correct timing will smooth out a "lopey cam"
Old Oct 14, 2005 | 10:04 PM
enkeivette's Avatar
enkeivette
Well I know I don't have the timing right, this is the first engine that I've assembled (from a shortblock) and installed myself. So I'm not really experienced. And the fastest engine I've been in control of before this was the old stock L48.
But the cam is a .520 .540 236 242 actual duration at .05 retro fit roller. What do you think, is that lopey?
Anyways I'll post a video tonight.
Old Oct 15, 2005 | 08:18 AM
bobs77vet's Avatar
bobs77vet
any body who has been fortunate enough to go to a Lars tuning for beer session has seen Lars take cars that were "Lopey" and that we all thought sounded good and make them run better an eliminate alot of the lope by concentrating on making the distributor run correctly by shimming the shaft and using new springs etc....and then he moves to the carb and the cars just purr....
Old Oct 15, 2005 | 08:56 AM
mandm1200's Avatar
mandm1200
I would think it should have a nice sounding tone at idle. By nice I mean lopey. There is no way that engine with that cam it going to purr like a kitten. Looking forward to the video.
Old Oct 15, 2005 | 09:47 AM
David Ey's Avatar
David Ey
Originally Posted by bobs77vet
......making the distributor run correctly by shimming the shaft and ....
Are you saying shimming the end play at the gear? How much clearance should there be?
Old Oct 15, 2005 | 10:39 AM
bobs77vet's Avatar
bobs77vet
i don't know the clearnances.........Lars used a box of shims and added them until the excess slop was removed but so that it still could have some movement...
To Engine Won't Stay On (Help)
Old Oct 15, 2005 | 10:49 AM
bobs77vet's Avatar
bobs77vet
so as i understand it the beveled gear will make the shaft rise up and alter timing by as much as 4* and shimming it makes the timing stay more steady
Old Oct 15, 2005 | 06:52 PM
enkeivette's Avatar
enkeivette
Who is this Lars guy? And why isn't he doing this to my car?! I'm not opposed to a free tune.
Old Oct 15, 2005 | 06:56 PM
David Ey's Avatar
David Ey
Ok, I forgot you can also shim the dist. to intake surface which is another question altogather. I was asking about the shim between the gear and dist. housing.
Didn't mean to steal the post guys. sorry.
