Got my car back from J&D after getting rear ended and everthing is perfect but they said my vented cap was wrong and put a non vented on. It seems to tight with all the seals. My vented had no seals.
What is the sure way to tell which one I need? My vented cap sure looks like the original.
From: Las Vegas - Just stop perpetuating myths please.
My books say '69 was vented but unless u have EVC on drivers side then that fuel tank cap becomes the press relief vlv. And yes they do have sometype of press relief to save the tank but not for normal operation - like in ur application.
BTW would u recommend J&D for a full paint job? Not trying to steal the thread but they do a lot of body work and someone i know recommends them for paint & body. I see them at Pomona swapmeet selling glass and detail parts. Specialize in corvettes and fairly local too. Compare thier prices? Perfect work?
They did a great job matching my red paint. So good I cant tell anywhere. I would recommend them for paint though I noticed one small run spot on my deck lid behind the passenger seat on the vertical flange edge but nobodys perfect.
I'm a little concerned they would recommend me the non vented cap when 69 has vented. They've been in business 20+ years.
What's the difference between a vented and non-vented cap? I was under the impression that the only difference is that the vented ones don't have a gasket and the non-vented ones do. I have the locking gas lid, which I bought used. It came with a gasket, which I assumed would be for 1970 non-vented cars and up, so I removed it. Is this wrong?
I've had my '69 since 12Feb76 and it looked to have an original non-vented gas cap. I still have the same gas cap on my car. My car was built on the first day of production, (SN00035), so I'd guess all '69s should have non-vented gas caps. My family has 2 other '69 Corvettes and both have non vented caps.
Ok guys, here's the long story.
None of my numbers book address the EVC sys directly. But all the vendor catalogs sell a vented cap through '69. 1970 is first year for nonvented caps. But really the important item here is the charcoal canister (EVC). On models that have an EVC the tank is unvented and tank vapor press flows through the charcoal and vapor is expected to be retained in charcoal. Ya, right with a 30 yr old canister. When the carb pri blades open above a port in the throat the eng vac pulls purge air from a EVC vent by eng vac through that EVC and removes the vapor along with. BTW it takes about 1/2psi tank press for sys to work and the non-vented caps have a relief somewhere near 5psi to hopefully save the tank from overpress - yes u could possibly hear ur own gas cap fart.
So what i'm saying is if u don't have a EVC inside the drivers side fender like on my '74, u should run a vented cap.
cicconjo, i also just bought a locking cap from Ecklers and the instructions say to leave the gasket out to run vented. Or install the gasket to use unvented. I expect it will work ok. Kind'a nice to have the option with one cap. And with gas prices now locking gas caps should be a popular Xmas gift.
Vented caps were on all Vettes through 1970 EXCEPT California versions. The CARB smog laws in California brought about closed evaporative emission systems in 1970 for California bound Corvettes (carbon cannister on driver's side of engine compartment below the vacuum tank, sealed fuel filler caps, evaporative fuel vents from the carb float bowls, ect.) DO NOT run your Vette with a non-vented fuel cap, you will have problems!
Would it be OK to use a vented gas cap on all years? Unless it's really needed, it seems using a vented gas cap would be the best way to go. (No backpressure on fuel flow, one less thing to go wrong.....).
Also by the way. You can put 20 gallons into a 68,69,70(?).... Some where along the way, GM started putting a filler tube that extended into the gas tank. This prevented people from completely filling the tank because the extended tube meant there was always air in the top of the tank. Maybe this was a safety concern and maybe it was to prevent people from pumping gas into the vapor return lines. Anyhow tank capacity was reduced by 2 gallons. If your tank has the extended tube, you can get 2 extra gallons of capacity by reverting back to a 68 or 69 filler tube.
