any one narrowed their own diff ?
Old Oct 17, 2005 | 01:08 PM
panchop's Avatar
panchop
Default any one narrowed their own diff ?
I am getting read to narrow the old ford 9 inch i picked up.I have cut off the old perchs and smothed it out. i cut of the old bearing housing but not to the width i needed. i just wanted to mock stuff up. so my plane is to buy the bearing ends , axles etc i need. then turn down a straight steel bar to the size of my axles. cut and true the ends to the correct leangth and weld the the new bering housings on over the steel bar. then i'll weld some reinforcing material to the housing. sound about right?
Old Oct 17, 2005 | 01:54 PM
norvalwilhelm's Avatar
norvalwilhelm
We use to narrow housing all the time. We would just cut them with a pipe cutter, remove the section we wanted and then using two angle irons clamp the 2 pieces back together and start tacking, going around and around. They seems to come out ok.
Old Oct 17, 2005 | 03:28 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
That's exactly the way a pro builder in my area used to do it, often he would still have to tweak it in an arbor press.....
To any one narrowed their own diff ?
