Cruise-In IV Veteran
Cruise-In V Veteran
Iron heads and boost
So, here I am thinking about iron heads again.
when every dollar is an uphill battle, I really want this turbo project to get underway. I can get iron heads for signifigantly less than aluminum heads.
I really want to run 16 psi on a 8.25 compression ratio with 64cc chambers and some speed pro dished pistons.
I already have my cam. 213/219 with I believe a 112 LSA, LPE L98 roller cam(it was a hundred bucks).
I can get something in iron that flows well in the sub .500 lift catagory pretty cheap.
I ran iron heads and 12 pounds of boost without a problem. I am switching to aluminum now but not because of a problem with detonation. Head for head a iron one will make more power then an aluminum one.
My 12 pounds of boost came in at a much lower rpm then you could get with a turbo. 12 pounds of boost with 8 to 1 compress gave me 14.5 compression at that boost and I could get it by 1500 rpm. This is really hard on the motor, no rpm and lots of compression.
With the turbo your rpm would be up and it could handle the increased booth better.
Cruise-In V Veteran
I was thinking something along the lines of some dart platinum series iron eagles or something. Vortecs will work too, but I am not sure how much I save when I buy the modified ones.
Concerning the roller cam, hydraulic roller will usually need 110-130lbs on seat, and 280-330lbs open. Have you considered the bee-hive type spring Comp sells?
Decide on the cam last, call the tech departments at a few diff cam companies to get their recomendation on cam specs for your final set up, this will ensure you get the best bang for you buck, blower cams usually have less lift and diff event timings then a NA eng
If you need GOOD iron heads I have a set. Double hump heads I had the valves opened up to 2.05s. Very nice heads and willing to sell for a good price if you need them. Make me an offer.
Cruise-In V Veteran
