75 350ci SB ?'s
Old Oct 30, 2005 | 05:52 PM
75stingem's Avatar
75stingem
Cruising
Default 75 350ci SB ?'s
Hey i got a 75 corvette with a small block , i bought the car about 6 years ago and just finished with the paint and am starting on the motor, i know the car has an edelbrock Carb and i recently put the edelbrock rpm performer intake manifold. what would i need to put the car at around 400 hp and how much will it cost, also how do i know if the car has aftermarket cams? when i bought the car the guy told me it had somework done to it and im wondering what it has, i recently found out about the carb... thanks for the help!
Old Oct 30, 2005 | 06:02 PM
marshrat99's Avatar
marshrat99
Well, 400hp is going to cost some major $$$ out of a 350. If you're not too much concerned with keeping your current engine numbers matching then you can achieve your HP goal with nitros or a blower. Either way, you've got to make a considerable investment. My bet guestimate is about $6-$8K either way. You'd be better off pulling you current numbers matching engine and buying a good 4bolt block to build.
Old Oct 30, 2005 | 06:36 PM
8DVETNUT's Avatar
8DVETNUT
My 2 cents :
Check this out
http://www.chevyasylum.com/chp/goodwrench1-1.html
or
http://cgi.ebay.com/ebaymotors/Chevy...temZ8009187218
Old Oct 30, 2005 | 06:44 PM
75stingem's Avatar
75stingem
Cruising
Whats the most hp i can get out of this motor? and what do i have to do to achieve this?
To 75 350ci SB ?'s
