Roots Blower questions
Are those short type roots blowers made by weiand and holley any good?
I was looking at the weiand 177 roots blower or the weiand 142. I think holley makes similiar units.
What kind of compression and motor do I need for one of these blowers? how much boost can I ran? Are they hard to install? Sorry, I know nothing about superchargers.
I have all the parts for the motor except pistons so I can pick whatever compression I need.
pro topline heads (200cc, 64, 2.02)
Comp cam SOLID 274/280 236/242 .535/.545 110LSA
750cfm speed demon carb. mech sec
Harland sharp roller rockers
short block
forged crank
pink rods
.040 block
I was going to get forged .125" domed pistons for ~10:5.1 compression(with a NA setup)
I have a big cowl hood so I wonder if the blower will fit under. Don't want to cut a hole in the hood.
I would need 8.1- 8:5.1 compression
Blower cam with widder LSA (113-114)
Bigger carb that is setup for a blower
Has anyone here done this??
Jim
As for the pistons, IMHO, go for a static C.R. of 8-8.5:1. (I would say higher, if it's for mild driving, lower if you want more boost and overall HP).
I made the mistake of going with a cam that's a little too large, for my 427 BBC.... If I had to do it over again (and may, in the near future), I'd go with one of the "blower" cams.
There are a LOT of guys that'll tell you to go with a monster carb for this application, but I would submit that your 750 is likely to be perfectly sufficient for your combination.
A quote from the book "Street Supercharging," (SA Design, Part No: SA17 ISBN 1-884089-29-1, www.cartechbooks.com) is as follows:
(referring to Mike Jones, a carb expert on forced induction systems)
However, Mike is quick to point out that a typical street engine (350 cubic inch) simply cannot use much more than 900 to 950 cubic feet per minute of intake volume. So even with a single 600-750 cfm four-barrel on top of a 6-71, you're not likely to reach the point where the carb can't flow as much air as the blower can feed the engine.
Jim
If you infact go to 9 to 1 your limiting your boost to 5 psi/6 maximum.
You get a snappier engine by running low compression and higher boost.
For a carb you need a boost referenced holley. The carb has it's power valve referenced off the boost side of the blower. Not the sucking side.
I run dual boost gages. ONe on the intake side and one on the outlet side of the blower and while the output can be at a good boost level the carb side is also reading a good vacuum level. If the carb is referenced off the carb side the power valve remains closed.
DO NOT run without a power valve. I run fairly lean, about 15-1 on normal driving and when the boost level crosses Zero and power valves are blown open and the ratio drops to 13-1.
This works. With dual 850 double pumps on the blown bigblock I can pull down a easy 15 mpg. The motor is snappy, runs very cool on the open road and never never fouls plugs.
Blower like about 112 lobe serperation angle on the cam and I do run alot of timing. Actually 43 degrees with a boost retart computer.
The 177 is a great little blower. It's about the same price as the 142, you dont need to spin it as fast, and it can even support a 454.
Stay conservative on the compression. I ran 8:1 on my 454 with 7 psi, never a problem even with questionable gas. Sooner or later, that 92 octane at the pump is going to be slopped out with thier extra 89 octane. And with the lower compression, the 177 has enough volume to increase your boost by just changing your pulley.
Like 632 said, stay a little conservative on the timing, 10-15 initial gives good idle and 32 total shouldn't melt stuff. Holley website has good info on this.
I have also run this combination for 4 or 5 years on the street and when I pulled the heads a few weeks ago the pistons are in like new condition, what little dicoloration or carbon came right off, no burned spots and I do run 15-1, my plugs are lean, I do run 43 degrees of timing while under light load, I do not need a fan while running on the open road, I never foul a plug ever and I can get 15 mpg.
As for snappy off the line performance 10 pounds of boost right off idle gurantees that snap.
Mine is not a race motor like yours but on the street as a daily driver or even long distance cross country it would put a race motor to shame.
As for high intial compression and lower boost levels that is not true.
This is not a pissing contest MIke. I have a combination that works and am sticking with it.
So adding the 30 built into the distributer with the 13 degree electronic and I did check it again with a timing light I am running 43 degrees total at 3000.
Marck I don't pretend to know all the theory but I do ask my engine with timing and boost and carb jetting what it likes and it tells me.
I do many many testing sessions until I get it worked out, forget theory, do the tests. Watch what the motor is telling you.
http://temp.corvetteforum.net/c3/zma...ginepage01.htm
For running down the road under light load and the boost in the intake actually in vacuum I am running that straight ignition setting of 43 degrees at 3000 like anyone else would set a car up. I have a MSD timming computer for the ignition curve.
When the boost level crosses zero the power valves are blown off their seats bringing the mixture to 13-1.
As boost climbs the boost timing computer pulls 1 1/2 degrees per pound out of the total.
Off a light I often see 9 or 10 pounds of boost so using math and starting at 43 if I was in fact reving 3000 minus say 1.5 time 10 pounds I would be at that point running 43-15 or 28 degrees.
Marck all timing is set by a curve, you always specify maximum advance. I hope I did not mislead anyone by saying 43 degrees because that is what is dialed into the distributer if you use a timing light. At 3000 you get 43 degrees.
I would not run a blower motor without a boost retart system nor would I ever consider running without power valves or even romotely consider running 11.5 fuel ratio in any street motor.
This is a street motor. It is not a race motor. I do cruise at 100 mph plus.
