C3 performance suspension alignment
Old Dec 16, 2005 | 01:01 PM
panic's Avatar
panic
Default C3 performance suspension alignment
hi all, could anybody give me the best suspension alignment numbers (toe/etc) for a C3 with the following characteristics:
SB engine lighter then stock (alu heads/etc)
lightened by about 400 lbs
rear lightweight spring
front transverse spring kit
polybushing all round
HD sways bars front rear
10'' rear bolts
adjustable QA1 all round round shocks
275/60/15 rear and 255/60/15 front rubber
for mainly track days or fast street driving.
thanks a lot/Giu
Old Dec 16, 2005 | 01:46 PM
big_G's Avatar
big_G
10'' rear bolts
thanks a lot/Giu
http://www.vbandp.com/instructions/h...ruct/align.htm
Old Dec 16, 2005 | 01:54 PM
rihwoods's Avatar
rihwoods
The advanced street is a good set up in link above....
Old Dec 16, 2005 | 03:02 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
I agree that the advanced street set up is a good place to start. Run as much positive caster as you can get. They recommend 2.75 but if you can get more then do it. The zero toe will be a little twitchy so if you don't like that then put a slight amount of toe-in in. The rear toe is very important for high speed stability. Those numbers are good as well.
Old Dec 17, 2005 | 01:59 AM
panic's Avatar
panic
thanks you've been very helpfull
Old Dec 17, 2005 | 02:19 AM
Retro78's Avatar
Retro78
Nice vette specs. Do you have any pics for us?
To C3 performance suspension alignment
