Can you recurve a "HEI" distributor
I see the article by Lars for recurving a non-HEI distributor, can something be done for my poor L48 HEI distributor?
That is where I started with my 80 L-48. It helped quite a bit on my stock motor. Of course, it lead to a head and cam change. Once you get started, the bug will get you and there is no going back. You will want more and more.....damn these cars.
I assume you are talking about this article?
How to set your timing for peak performance by Lars
Although the method Lars gives in this article is not recommended for setting up HEI the theory still applies to HEI.
This paper on vacuum advance units is also valueable.
Vacuum Advance Units by Lars
Basically you want the timing to advance sooner as the RPMs increase. This can be accomplished with heavier weights and/or lighter springs than stock. I found some really heavy weights in an old Buick Distributor. Using the old trial & error method I grinder modified the weights and eventually got them to work out perfectly.
Originally Posted by SomeSayIllFixIt
Is there any place that sells heavier weights/ lighter springs?
So when ya buy a spring/weight kit (and throw away the weights) is there progressively lighter springs in the kit so you know at what point you've hit the right spring and we are looking for peak advance at what RPM??
All in at 2k if I recall correctly. There is three gauges of springs in most kits. You can also mix and match to get you there. I am using a light and medium in my distributor.
I wouldn't say "need" it but you might give it a shot and see if you feel any improvement in performance. Definitely read the paper of Lars that is linked in the above post by Boofers.
Lars recommends that you not use the weights provided in the kits, just use the stock weights. (Make sure the weight pivot-bushings are good though) The Springs are the important change. I think I'm running the lightest, I don't remember if Lars changed my spring setup...
-Chris
-Chris
The advance curve kits have been available at auto parts stores a long time as it's a normal part of performance tuning. The weights were never good in any I've seen & I never used the weights, just the springs.
