brake urgent question
Old Dec 28, 2005 | 12:04 PM
panic's Avatar
panic
Default brake urgent question
hi all, i have a brand new brake kit of willwood caliper (and rotor) for the front of my '77 C3 and willwood caliper for the rear BUT as the front rotor is still as new and the rear one is pretty tired..could i use the front rotor which come on the kit for the rear? both are oem 11.75'', is there any reason i wouldnt be able to fix this front rotor to the rear, they look the very same thing to my eyes... all advices will be very welcome as i'm fixing the kit right now, thanks.
Old Dec 28, 2005 | 12:17 PM
SteveG75's Avatar
SteveG75
No, rotors are different. Rear rotor is set up for the parking brake.
Old Dec 28, 2005 | 12:21 PM
panic's Avatar
panic
steve, could i custom fix the front rotor at the rear at all? pardon me but if the measures are the same i do not see any big trouble in adapting it, maybe apart from not beeing able to fix the parking brake??
thanks for your cooperation..
Old Dec 28, 2005 | 12:39 PM
SteveG75's Avatar
SteveG75
Personally, I don't know of anyone who has done it. There are a lot of dimensions involved and if you are out one little bit, your brakes may work poorly or not at all.
IMHO, brakes are one area that it is not worth taking short cuts on. You are talking about putting your life in jeopardy if you can't stop the car. Seems stupid to try and pinch pennies here.
Old Dec 28, 2005 | 12:41 PM
Solid LT1's Avatar
Solid LT1
Cut loose with $60 for a set of new rear rotors. I'll sell you a set for that price if you can't find them.
Old Dec 28, 2005 | 12:45 PM
panic's Avatar
panic
i couldnt agree more steve...
Old Dec 28, 2005 | 01:17 PM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
I've never measured it myself, but I understand that the offsets are slightly different front to back. This could make the rotor not in the center of the caliper. It should be in the center within .020" or so.
Other than the parking brake, there is no reason not to be able to swap front to rear.
Old Dec 29, 2005 | 02:15 AM
panic's Avatar
panic
hi, believe it or not last night i've tried to fix a front new rotor in the rear of my '77 and it went streight trough in , the inside of the rotor was machined exactly to fix the parking brake, also the only difference i've noticed between front and rear rotors is that the rear one has the internal wall 1 mm higher then the front one but anyway the parking brake surface gets within the internal touching area all right...maybe precision brake co. sent me a rear instead of a front kit?
Old Dec 29, 2005 | 08:34 AM
kb2fzq's Avatar
kb2fzq
Ahhhh...I don't think that happened....
Old Dec 29, 2005 | 01:18 PM
panic's Avatar
panic
you're right, it didnt happen, i was wrong thinking i could get that rotor in the rear infact it SEEMED i could but at the end of the day i had to take it back and fix the old item
Old Dec 29, 2005 | 01:21 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the front and rear rotors are different and they are not interchangable...the hub thickness is different
To brake urgent question
