383 stroker owners, Please chime in
I went with the more beefy short block in the event I later wanted more power. My engine was spec'd using the Dyno software. I wanted as much HP as possible but I did not want a big high lift cam shaft sound with bad idle and poor vacuum.
So what we came up with was a all forged short block with:
4340 Eagle Crank
Weisco flat-top pistons
4340 H-beam full floating rods
.500 lift 112 lobe seperation roller cam
AFR 195 Heads
Speed Demon 750 with Vac 2nds
Runs and sounds like a big block, specs at 385 RWHP. Hope to get it dyno'd in the spring.
Audie
4340 Eagle Crank
AFR 195 Heads
Audie
4340 Eagle Crank
AFR 195 Heads
Audie
4340 Eagle Crank
AFR 195 Heads
Audie
Originally Posted by Gordonm
Try here http://dragvette.com/
Thakns, Nice product great price... cheap insurance... $120
Originally Posted by carl a
hope your like me and have those 1/2 shaft safety loops in !!!!!!!!!!!!!!
I have a 388 which is pretty close to a 383
It has 4.125 JE custom forged pistons with Sonny Bryant "billet" small journal crank that should provide me with enough strength for any other crazy ideas I may come up with some day. The stroke is 3.625" so with the 6.0" small journal Crower Sportsman rods I get very little side wall thrust for less rotational friction and wear.
I too went with a solid roller custom ground Comp Cam. The part number is 12-000-9 which is the mechanical roller blank and the grind numbers are CS 4875S/4876S SR112+4. The lobe separation angle is 112 degrees. This cam has 4 degrees ground into it to improve the lower rpm torque so when it's installed at 108 degrees it will essentially be straight up at 112 degrees. The lift is intake .616"/ exhaust .622" with 1.6 rocker arm ratio. Duration @ .050 is Int. 248 & Exh. 254 . The cam timing events @ .050 are 16 52 63 11. This also compliments the 11:1 compression
The heads are AirFlow Research 210cc Race Ready. They come with 100% CNC ported combustion chambers, intake & exhaust ports. Valve sizes are 2.080 intake & 1.60 exhaust. Upgrades we ordered from the factory include Titanium Retainers, Pacaloy Valvesprings with .100L valve upgrade. I went with the 210cc heads because of my engine being only a 388cu in. I would have gone bigger for the added air flow, but I chose the 210cc to help keep the velocity intake charge up for improved torque & throttle response for street driving.
That's about it
Oh yeah, the half shaft safety loops are a very good idea
That's about it
Originally Posted by Redshark6974
could we get more specs on your cam? Sounds like a setup i went with..nice idle, but as much HP as i can get with what i have.
Part Number: 12-000-8
Custom Grind: CS 3109S / 3112S HR112+4
Intake Exhaust
Gross Valve Lift: .513 .510
Duration @ 276 290
.006 Tappet Lift:
Valve Timing: Open Closed
@ .050: Int: 2 BTDC 38 ABDC
Exh: 51 BBDC 1- ATDC
These specs are for cam installed @ 108.0 Intake Center Line:
Intake Exhaust
Duration @ .050 220 230
Lobe Lift .3420 .3400
Lobe Seperation 112.0
Sorry I took so long to get back to you...
Audie
I have a big-bore 383...
AFR195-ported
10.7:1CR
XR280R Solid Roller
91 octane pump gas
I don't know how much power it makes, but my times are in my sig (at 4000' elevation).
AFR195-ported
10.7:1CR
XR280R Solid Roller
91 octane pump gas
Location: San Diego - Deep Within The State of CONFUSION!
He was not to thrilled with the heavy hyd. rollers if the motor is going to see over 6000 rpm. Plus I would need new roller lifters pushrods rocker arms and springs. I am going to use my existing AFR heads. For the few extra ponies he said the solid cam will more than be enough for 500+ HP.
Cam Specs:
Intake Exhaust
Duration @ 276 290
.006 Tappet Lift:
Intake Exhaust
Audie
Intake Exhaust
Duration @ 276 290
.006 Tappet Lift:
Intake Exhaust
Audie
