HEI, EMP and C-3's
But points won't do you any good; virtually all vehicles around you will be stalled ... you'll be stuck anyway ... and everyone around you will be crazy ... ranging from dumbfounded to violent.
If you're really serious, best bet would be to keep in your car: a good pair of sneakers, cash, bag of trail mix, can of water/beer, a good pistol and plenty of guts & self-determination.
In the unlikely event of repeated EMP attacks, I would expect a spike in demand for old points distributors & coils & parts, carbs and intakes.
BTW, several years ago ... US police departments & defense contractors tested a rocket-powered wheeled skateboard affair ... is launched toward underside of offender's vehicle ... emits EMP ... kills most offender's engine. I haven't heard of it in routine use ... hope I never do.
You should wrap both your HEI and your head with heavy aluminum foil. That way your car will keep running and you won't suffer from memory loss during an EMP attack.
EMP proof buildings, built by the US military, utilize Mu metal shielding. The entire building; ceiling, walls, floor, consists of an unbroken series of metal shielding welded together. Doors have copper "fingers" to prevent breaking continuity of the shielding. The metal prevents penetration by H fields (and E fields also).
Put a spare HEI module in a metal can that has a screw on metal lid. You'll be protected.
If your room or building need only be protected against E fields, just continually covering walls, ceilings, floors with soldered together copper screen wire will be OK.
Radio waves are all E fields at distances far from the transmitter. An electro magnet works by the H fields that the electric currents flowing through the windings create.
High voltage electronics like that in an HEI module may be susceptible but I put it less likely and especially if you still have the chromed shielding over your HEI and wires. That chrome shielding is there because a fiberglass body doesn't form any kind of e-field shielding from what the HEI creates all on it's own and messes with the radio and other electronics near by.
And here you thought EMP was a terrorist weapon. You've been driving around with a mini EMP generator in your car for years......it's called HEI!
How can magnetic fields generate large voltages, currents? Consider a a high voltage transformer (like for a CRT tube power supply) the output winding can have extremely high voltages and related electrical currents. However, the output winding's high voltage/currents are induced by the magnetic fields between the transformer input (primary winding) and output (secondary winding). I believe this is why the EMP pulse produces damaging voltages and currents in electronic circuits; the EMP pulse magnetic field induces these currents and voltages in electronic circuits similar to the process that is taking place between the primary to secondary windings of a transformer. This is my understanding of the process.
Anyhow the EMP pulse does, cause damaging currents and voltages in electronic circuits. Everyone agrees about this. During cold war days, the largest nuclear weapons, I believe, were the 50 Megaton bombs made by the Russians. These bombs were intended to be exploded in the upper atmosphere over the United States (two or three bombs would be required). The resulting EMP pulse would destroy power line grids, televisions, radios, computers, etc, just about everything electronic that was not hardened against EMP. Todays microprocessor circuits are expecially vulnerable.
The 50 Megatoners were not indended to be used against cities. Several smaller nuclear bombs, exploded in the atmosphere, would do much more damage that one single 50 megatoner exploded in the atmosphere. At least that's what I uderstand about the purpose of the 50 Megatoners.
