What Intake with ZZ4 and Fast Burn Heads
Do to clearance issues with the Corvette Hood, I am looking for intake manifold suggestions I can use on the ZZ4 with Fast Burn Heads? I need a spreadbore design to use with Speed Demon 650.
Will Edelbrock 2101 work? Any suggestions?
Aren't all Demon carbs squarebore? It's best to use a vortec manifold with the fastburn heads. Both Edelbrock 7116 and GM 12366573 will work and are low profile but will cost you some HP,maybe up to 20. I would try to use a air gap 7516 or GM single plane intake with a drop base air cleaner if possible. Maybe someone here has done that. I'm using the 7516 but I also have a aftermarket hood.
Air Gap with L82 Hood?
Your right on the Demon's. Duhhhh....Thanks, was chasing wrong manifolds. Has anyone one used an air gap manifold with L82 hood? Are single plane manifolds "street friendly"?
yeah i have the same setup as you do with an endurashine rpm on it with a k and n air cleaner up top. But i think my hood is the hi rise. i have lots of clearance
Is the hood you have an aftermarket? Or is it a L-82?....sounds like I can use a RPM manifold with a drop base air cleaner. Need to ck clearance with molding clay, but they may be the way to go. Thanks.
I think the performer rpm, air gap, and gm single plane (ZZ383 test manifold) are all about the same height. I did a quick search using "airgap hood clearance" and came up with several threads discussing this. Lots of talk about different intakes under stock hoods. You should find an answer there.
Location: Las Vegas - Just stop perpetuating myths please.
Ur misleading which heads u have.
ZZ4 didn't come with the Fast Burn Heads - came with corvette aluminum heads with the original intake bolt & runner patterns.
Fast Burn Heads have a vortec style runner and bolt pattern that uses a different intake. Both Edelbrock and GMPP sell intakes that fit those heads - but which heads do really u have??? Part number???
Speed Demon is squarebore carb. Why would u need a "spreadbore design to use with Speed Demon 650"???
cardo0
Originally Posted by supervett77
actually its a fastburn motor with a zz4 bottom end i know because i bought one for 3899 couple years ago.
cardo0
cardo0
I was mistaken about the spreadbore.
My question was what manifold to use, knowing that the FAST BURN heads require a different intake for the reasons you pointed out.
I was looking at AFR heads, but I would have to change the pushrods and roller rockers I just installed with the LT4 HOTCAM.
So, GMPP Fast burn heads with RPM manifold, using drop bas A/C.
I think this is were I will head. Thanks.
Easy on the caffine Dude.
Cardo.....I have a ZZ4, that I want to put the FAST BURN heads on.
Ok, thats making sense now. But 1 thing to take note is that anytime u change heads, cam, vlv train, or deck block u need to verify p-rod length. And its easy with a checker tool from Manley or ProForm ($10). Just follow instructions and u can buy good corrected length p-rods <$100 these days (Jeg's or Su....) - well close enough to do the job right.
1 more thing is that i recall the FAST BURN heads are a larger chamber than the ZZ4 (corvette) heads. What i'm saying u may not see as much gain with the loss in c.r. along with the bigger cam/more overlap.
For less money u could have those vette heads ported to similar flow numbers and use the original intake. Well just a thought as u may not know a reliable head porter and end up with amature head work so use caution. Sometimes its fun to meet skilled mechs locally and sometimes its a big dissipointment.
Good luck. cardo0
ZZ4 Heads on 1981 Corvette
I have a similar issue.
How can I make sure I have the correct intake manifold for aluminum ZZ4 heads (part # 0-12367712) in a 1981 Corvette. I want a good breathing intake that will still clear the hood.
I bought the car at an auction and I suspect the original engine was swapped out and the ZZ4 heads were installed, but the original intake and headers were retained, topped off with a Holley 750 dbl pumper.
I currently have a chronic oil leak at the back of intake manifold and suspect it's because of the intake.
I would also like a recommendation for a good set of headers. The current headers are very restricting and leak, even after multiple attempts at replacing the gaskets. I saw some very nice Hooker Sidepipes the others day.
Any suggestions would be appreciated.
