Adjustable Timing Pointer
Old Jan 31, 2006 | 09:31 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Adjustable Timing Pointer
I just finished up installing a new set of Harland Sharpe Roller Rockers and an Edlebrock RPM Airgap. While I was at it, I set the end play on my distributor and replaced the limit bushing for the centrifugal advace. Now that I have it all back together and running I was setting my timing. I have it set at 36 degrees all in by 3000 RPM by using a combination of a light and a medium spring. Total with vaccum advance is around 52 degrees. This is all according to my dial back timing light and my Tavia adjustable timing pointer.
Here is where my question comes in, is there a way I can verify my pointer is setting where it should be and has not moved?
Thanks for any help you can offer.
Eddie
Old Jan 31, 2006 | 09:39 PM
David Ey's Avatar
David Ey
You can poke something in the sparkplug hole and rotate crank slowly by hand and feel for tdc. They make a tool for this.
Old Jan 31, 2006 | 09:44 PM
Eddie 70's Avatar
Eddie 70
I was thinking of pulling the plugs and getting a bolt of the correct thread and using that as a stop. Rotate the motor one direction till it comes to the stop. Mark the balancer. Rotate the motor in the other direction and mark the balancer. Remove the bolt and got to a point halfway between the two marks and this should be where I need to put my pointer on Zero.
Does this sound correct? All I need to know is what size bolt to come up with. Is that a 1/2 thread?
Old Jan 31, 2006 | 09:46 PM
David Ey's Avatar
David Ey
They do it that way too Eddie. I think it is a 14 mm but not sure.
Old Jan 31, 2006 | 09:50 PM
Eddie 70's Avatar
Eddie 70
I am running Trick Flow heads and the socket size for the spark plugs is 5/8".
Old Jan 31, 2006 | 09:54 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i like ths idea of really long stiff rubber hoses....sticking bolts in there makes me nervous
Old Jan 31, 2006 | 09:57 PM
ltlevil's Avatar
ltlevil
14mmx1.5 pitch. I'm sure of the mm but I'm only 90% sure of pitch. If any doubts take a plug with you to the hardware store and see what nut it screws into, this will tell you.
ltlevil
Eddie 70's Avatar
Eddie 70
I am with you on that one also Bob. That is why I was thinking of removing all of the plugs so I could have a little more control of the motor while I was rotating it. Splain a little more about your rubber hose idea, I may like it better.
Old Jan 31, 2006 | 10:51 PM
SIXFOOTER's Avatar
SIXFOOTER
Sticking a bolt in there (or anything of size and hardness) is a bad idea. Use a thin plastic stick and carefully rotate the engine by hand to get#1 to TDC, It should be at 0 according to the mark on the balancer and the marker.
Old Feb 1, 2006 | 08:07 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Default hmmmm
I wouldnt go sticking anything hard in my cylender either, to many opprtuinities for gremlins or murphy to raise their ugly heads!!!!
This can also be done effectively with a good piece of rope. Rotate the motor one direction till it comes to a stop. Mark the balancer. Rotate the motor in the other direction and mark the balancer. Remove the bolt and got to a point halfway between the two marks and this should be where I need to put my pointer on Zero.
The eastwood comapny sells a neat tool that does the job well. its a whistle that stops blowing when the piston is at TBD 22 bucks a keeper for the tool box.
http://www.eastwoodco.com/shopping/p...=1&keyword=TDC
tim
Old Feb 1, 2006 | 08:33 AM
djgrelli's Avatar
djgrelli
I have a whistle that I purchased from Eastwood for 10 Bucks. Screw it in place of the spark plug (has multiple adapters) rotate engine ( I use long bolts in the crank pulley with a breaker bar) and when the whistle stops you're at TDC. I use it for setting my rockers as well. Never lets me down.
Old Feb 1, 2006 | 09:14 AM
BigBlockk's Avatar
BigBlockk
This is the preferred method for finding TDC on an engine that has the heads installed. You do this when degreeing a cam or timing the ignition. Here is the tool to use.
http://www.jegs.com/webapp/wcs/store...tegoryId=23395
BigBlockk
Later.....
Old Feb 1, 2006 | 09:55 AM
lars's Avatar
lars
You can't use a soft stop like rope, plastic, rubber, or a whistle to determine TDC within the tolerance needed for setting up a timing tab. You have to use a hard stop like a bolt or the TDC indicator shown by BigBlockk (which is just an adjustable bolt). A hard stop will not do any damage to the engine/piston as long as it has been deburred and does not have a sharp edge/corner, and as long as you show reasonable care in the amount of force you use when running the piston up against the stop. You have to get repeatable data within 1 degree when setting up a tab, and you can't repeat within 1 using a compressable or cushioned stop system.
Old Feb 1, 2006 | 11:25 AM
SIXFOOTER's Avatar
SIXFOOTER
OK, I'll agree with that
Old Feb 1, 2006 | 05:47 PM
Eddie 70's Avatar
Eddie 70
BigBlockk
Later.....
Cool tool. I guess I will order one of those to make the job just a little less painful.
Old Feb 1, 2006 | 07:47 PM
Kid Vette's Avatar
Kid Vette
Don't buy the POS from Jegs or Summit. I bought one and the threads were so screwed up I couldn't screw it into the spark plug hole. I got one from Crane Cams. Works like a charm.
Old Feb 1, 2006 | 07:56 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I got one of those with a cam degree kit and it didn't fit the threads either. I used a straw to find the piston at TDC. McDonalds has those big fat sturdy ones.
To Adjustable Timing Pointer
Old Feb 4, 2006 | 02:30 PM
Eddie 70's Avatar
Eddie 70
Mark, Kidvette, thanks for the link. I just ordered the Crane piston stop from Summit. Should be here Wednesday.
Old Feb 8, 2006 | 02:07 PM
Eddie 70's Avatar
Eddie 70
Got the stop in today. Gonna see where exactly my pointer should be.
Old Feb 8, 2006 | 03:25 PM
Eddie 70's Avatar
Eddie 70
Okay, here is what I have found out using the stop so far. Right now going in the correct direction of rotation I am 0 degrees TDC. In the opposite direction or rotation I am at 8 degrees TDC. I guess it is correct to assume that I need to remove the stop, move the engine to 4 degrees TDC and put then align the pointer to this point. This should be Zero TDC from now on.
I am going to fly into it thinking this anyway.
Someone correct me if I am wrong.
