Cup Holders
![](/forums/images/ranks/500-1000.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Ok, who has them, and where do you buy them. I saw a photo once of a cupholder that fits on the emer brake handle. Anyone know a source for such item, or have other suggestions.
Txs, Des
![](/forums/images/ranks/3k-4k.gif)
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
I got mine from Ecklers many years ago. They work great, use them all the time.
![](/forums/images/ranks/2k-3k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
If you have a drink in the cup holder under the e-brake won't it get in your way when you shift? And won't it be difficult to set the brake?
I have a cup holder from wallmart that is ugly as sin, but it holds a 42oz drink securely and out of the way. It fits in the ash tray.
![](http://www.codymercantile.com/images/mf/c5369p.jpg)
This is the one I use. The clamp fits inside the ash tray and then expands to hold it in place.
~Jay
[Modified by Jay M, 2:06 PM 8/8/2001]
~Jay
Btw Pat, you and I should hook up one weekend. Our pair of '69s should turn some heads
![](http://www.corvetteforum.cc/ubb/smile.gif)
Checked with the "Last Detail". Didn't have any versions that I liked.
Des
![](/forums/images/ranks/100-500.gif)
I bought the wooden dual holder that slides on the ebrake handle at Last Detail. It would not slide on far enough to avoid interference with shifting (4spd). I removed the foam from the sleeve (pry the glue from the alum) and modified the sleeve (cut and rearranged the foam). The holder now slides on far enough and works well. Brake lever will work (if there are no drinks present).
