Purchasing Comp. Cams Rocker Arms - Suggestions?
Old 08-09-2001, 03:26 PM
70454's Avatar
Default Purchasing Comp. Cams Rocker Arms - Suggestions?
I am purchasing Comp. Cams #1411-16 Roller Tip Rocker Arms for my 1970 454. Is this a good move? What performance/advantage(s) should I expect?
http://store.summitracing.com/partdetail.asp?part=9398
Thanks in advance. See you in Carlisle.
Matt
Old 08-09-2001, 06:01 PM
73 LS-4
73 LS-4's Avatar
Default Re: Purchasing Comp. Cams Rocker Arms - Suggestions? (70454)
I was considering these as well, let us know how they work out.
Pat Kunz
Old 08-09-2001, 06:25 PM
Gordonm
Gordonm's Avatar
Default Re: Purchasing Comp. Cams Rocker Arms - Suggestions? (73 LS-4)
I have the similar ones for a small block and have been very happy. they are more accurate ratio wise than stock arms. Your lift will be what the cam says and not less like with stock arms. A slight improvement in hp but probably not anything you will feel. They are much stronger than stock and you only need to go to a full roller rocker when spring pressure is over 350lbs. Usually roller cams need full roller rockers. these will be fine for your application.
Old 08-09-2001, 08:12 PM
LT1man
LT1man's Avatar
Matt,
I hear that chicks dig roller tips.
LT1Man
Old 08-09-2001, 10:40 PM
70454's Avatar
Default Re: Purchasing Comp. Cams Rocker Arms - Suggestions? (LT1man)
No....I heard they dig roller-SKATES. :U
Old 08-09-2001, 11:12 PM
Ganey
Ganey's Avatar
Matt
Yes, 1.72. A little more lift as stock measure less than specs. & reduced valve guide wear.
:cheers:
Old 08-10-2001, 09:17 AM
mulchie
mulchie's Avatar
Weather for your drive from Philly to Ohio will be dicey. I'd leave around 10am. We can put your roller tips on tonight. Won't be that tough on hydraulic lifters.
Old 08-10-2001, 11:18 AM
SW73RAT
SW73RAT's Avatar
Default Re: Purchasing Comp. Cams Rocker Arms - Suggestions? (mulchie)
70454
You're going to love em!! Like Ganey said the are 1.72 so you get a little more out of you cam. When I built my LS4 I went with those along with an XE268 cam w/lifters, springs retainers etc. The only suggestion I have is you will need to install new push rods as they mate with the rockers. I used the 3/8" moly push rods from Comp for use with guide plates (hardened shafts). With the rebuild the whole package made a very noticeable difference in in my 73.
Steve
73 454/4spd Black on Black Roadster
:troll
To Purchasing Comp. Cams Rocker Arms - Suggestions?
Quick Reply: Purchasing Comp. Cams Rocker Arms - Suggestions?
