edlebrock carb 2small????
Old Feb 25, 2006 | 05:28 PM
75yelloray's Avatar
75yelloray
Navigator
Default edlebrock carb 2small????
hi, im new to the corvette world. i recentley bought a 75 stingray with a stock 350, headers and no cats. the guy i bought it from says the motor is rebuilt. auto tranny. i was crusing around about 70 miles from home when it started floodind and running rough, i made it to an autozone and the quadrajet card was pouring gas from where the throttle linkage is. the only carb the had was a edlebrock performer 600cfm, so i bought it and had to remove the egr and put a plate with a gasket in its place, also a adapter so the carb would fit the stock intake. does it matter what adapter i use? the open or the on with the 4 holes? cause now it wont spin the tires like before and doesnt seem as fast. is it to small? i was in a bind and a long way from home. any help would be appreciated. thanks
Old Feb 25, 2006 | 05:33 PM
comp's Avatar
comp
no it's OK if you do a bunch of mods you'll want bigger but it will work fine
Old Feb 25, 2006 | 05:36 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Rebuild the Qjet & ebay the Edelbrock
Old Feb 25, 2006 | 06:19 PM
Kalway's Avatar
Kalway
To edlebrock carb 2small????
