Pittman Arm R&R
Pittman Arm R&R
Getting ready to remove my power steering Pittman Arm and replace it with a manual one. Already removed the centerlink, but it looks like the new manual centerlink needs to be installed or a massive piece of pipe needs to be used to hold the Pittman arm to break the nut.
Probably not a good idea to put that much stress on the steering box?
Location: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
One the nust is loose, use a pitman arm puller, or a large picle fork to get separate the arm fromthe steering box
tim
Use an air wrench on the nut. Off in a jiffy with no leverage problems. It's the socket size that's a problem - 1 3/16" or something like that. Bought one at Sears.
If you have the set up, definately the best way
Been trying to figure out the size of the Pitman Arm nut. It measures 1 5/16" on the flats and 1 1/2" to the points. Just got a 1 1/2" socket and it's too big. I think it's a 1 5/16" six point?
i had to heat my pitman arm up to get it off.....it was a real chore even with a puller and the torch....and it was sitting on the work bench in a vise while i did this....
1 5/16 is correct. I use a 3/4" socket set to break them loose then heat the arm with a propane and use the $7 tie rod puller and an impact gun. Works ever time.
