Interior light problem
I replaced the headlight switch and still, no dash lights. Interior lights come on with door open but only lower compartment lights. When i turn healdight switch, the t-top light is off and still no dash lights WTF?
I checked ground and fuse and all is OK. Any ideas? :crazy:
Re: Interior light problem (wombvette)
Do you have tail lights?
[Modified by 82dukman, 12:24 AM 8/20/2001]
Re: Interior light problem (82dukman)
get you a volt meter or a test light and start tracing. I would start with the top light. Check power at the bulb holder then continue back, get a wiring diagram u will probably need it
[Modified by 71,454,4spd, 11:36 PM 8/19/2001]
Re: Interior light problem (71,454,4spd)
I thought someone might have had a similar porblem with an easy :rolleyes: fix
