faded paint
Old Apr 23, 2006 | 09:58 PM
mdj21's Avatar
mdj21
Default faded paint
is there anything that can be done about sun faded paint? (short of a repaint).
unfourtinatly, my 73 vert had to sit out side for about two years. there is now a very noticable diference between the paint on the rear deck that was in full sun and the paint that was under the convertable top.
a repaint is in the car's future, just not right away. is there anything that i can do about this to try to make it look a little better?
thanks,
Mike.
Old Apr 23, 2006 | 11:31 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
There's lots of good paint cleaners on the market you can try. Meguiars has a few different ones that might help. You may find cleaners work best using a 10" power buffer that you can find pretty cheap. If you get it cleaned up. apply a good wax afterwards. Goog Luck
Old Apr 24, 2006 | 05:54 AM
mdj21's Avatar
mdj21
thanks, i'll give that a try.
i've got an old power buffer. haven't used it in a few years.
hope this works.....
Old Apr 24, 2006 | 07:31 AM
rclinton's Avatar
rclinton
Veteran: Marine Corps
Default Faded paint
I used 3M glaze until I got mine repainted. Works wonders for faded paint. Semper Fi Bob
Old Apr 24, 2006 | 07:41 AM
vettfixr's Avatar
vettfixr
Check out Reviving Old Paint.
http://mywebpages.comcast.net/vettfixr/page5.htm
Old Apr 24, 2006 | 07:51 AM
mdj21's Avatar
mdj21
thanks, guys.
i'll give those suggestions a try.....
To faded paint
