looking for specs on TRW 2300 F piston....
When my 1966 427 was rebuilt by previous owner he had TRW 2300 F pop up pistons installed........I put on Endlebrock Alum heads as a winter project a few years ago , but didnt take the time to measue the dome of the pistons .......anyone know the wherabouts of the specs of TRW pistons , block is .30 over , block was milled enough to remove the engine numbers & my heads have 110 cc semi open chambers.....trying to compute compression ratio........ :confused:
[Modified by StrayDog, 12:45 PM 8/22/2001]
Re: looking for specs on TRW 2300 F piston.... (StrayDog)
Straydog, according to my TRW catalog, your L2300F pistons have a .140 dome height and with 109.4 cc chambers and 30 over pistons gives you 9.43 compression. Hope this helps. Hershey
Re: looking for specs on TRW 2300 F piston.... (hershey2@surfsouth.com)
I'm using the same piston with 104 cc heads and approx. .010 deck height. I figured my comp ratio at 9.6 to 1. So, 9.4 to 1 sounds about right, depending on deck height.
Regards, mark :chevy
