81 350 Engine noise
Old Jun 13, 2006 | 07:17 PM
81vettelover1's Avatar
81vettelover1
Default 81 350 Engine noise
After getting on it from a red light I started to hear a noise. After arriving at home I lifted the hood and at first I thought it was the water pump. So I changed it and stated it up and the noise sounded worse than before.So I took off the belts and still the same. Sounds like someone in the engine with a ballpeen hammer.Almost goes away at idle,but bring up the RPMs and hammering starts. It does not seem to miss or run and different. Please help... Thanks Randy
Old Jun 13, 2006 | 07:23 PM
SIXFOOTER's Avatar
SIXFOOTER
what part of the engine is the noise coming from? Is it hammering or clacking? might just be a collapsed lifter or rocker nut backed off. If it is hammering it can be a bad bearing. Look at the exhaust manifold gaskets, could easily be a leak.
Good Luck, let us know
Old Jun 13, 2006 | 07:54 PM
81vettelover1
Sounds like maybe the top of the engine in the front. I would have to say maybe more of a real fast hamming noise. Cant really tell what side.
Old Jun 13, 2006 | 08:00 PM
bickel's Avatar
bickel
loose rocker arm????? pull valve cover and check
Old Jun 13, 2006 | 08:34 PM
81vettelover1
Ok pulled valve cover off and on passenger side one of the rockers looked like it was off to the one side. So I grabbed ahold of it and there is about half an inch play back and forth.Not really loose but I could move it back and forth. Is that maybe the problem???
Old Jun 13, 2006 | 10:10 PM
a1sensei's Avatar
a1sensei
Do yourself a big favor and buy a mechanic's stethoscope (about $10 at any auto parts store). It will show you where the noise is. God bless, Sensei
Old Jun 13, 2006 | 10:52 PM
mandm1200's Avatar
mandm1200
If it's an automatic, put it in gear and step on the brake and the other foot on the throttle. If the noise picks up more than the rpms, I would say it a bearing. A lifter is more of a tick, a bearing is more of thud or hammer sound.
Old Jun 16, 2006 | 07:54 PM
bickel's Avatar
bickel
81's are famous for the cam's going flat made of butter let me guess you have around 80,000 miles on your engine???? if not I would recomend a valve job if you do not know how and want to learn there are some great threads here on it or type in valve adustment on google I would explain but I am not a pro so do not wish to give bad advice if the cam is not flat one of the retaing bolts may have gotten loose the one turned to the side !! Oh yeah I have an 81 with 80,000 miles on it.
Old Jun 16, 2006 | 08:16 PM
Richard Cooper's Avatar
Richard Cooper
I don't think that you should be able to move your rocker back and forth a half an inch. Look for the lars method of valve adjusting and try to adjust your valves. I did my 81 and it made it a lot quieter. Good luck.
Old Jun 16, 2006 | 10:21 PM
SIXFOOTER's Avatar
SIXFOOTER
LOL, No you should definately NOT be able to move the rocker a half inch. Back the nut off, realign the rocker and rod on the valve. Rotate the crank so that vallve is off the lobe and then readjust the valve. Fire it up and make sure the valve is working, moves he same amount as the others. There is a possibility that the cam lobe is wiped, but maybe the nut just backed off
Old Jun 16, 2006 | 10:25 PM
JBB's Avatar
JBB
That pushrod (on the loose rocker) could be bent. Pull that rocker off & remove the pushrod. Roll it on a flat surface to inspect.
Old Jun 16, 2006 | 11:00 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
yup, rocker arm is your problem. question is, why?
check the pushrod, but i'd bet that the cam is 'flat'. once you get everything back together, run the engine with the valve covers off. be prepared because this WILL make a mess. you won't have to run it very long but if you have a bad cam, one (or two, or three...) rockers won't seem to move as much as the others.
http://store.summitracing.com/partde...5&autoview=sku
Old Jun 16, 2006 | 11:53 PM
LannyL81's Avatar
LannyL81
If you have the stock 624 heads....good chance that the loose rocker was caused by the stud coming out of the head. I had three of those studs come out at one time.
Do a visual check on the stud height of that one rocker...bet it has come out a bit. You can drive it back it and it will stay for awhile...but not a long while. Time to pull those heads and throw them away. They are also most likely cracked. Time to spend some money and get a nice set of heads.....but ouch....its going to cost a bit.
Let us know what you find.
LannyL81
Old Jun 17, 2006 | 07:44 AM
81vettelover1
Ok here is the rest of the story. I pulled the heads off and the one rocker that was sitting sideways was all beat up where it ride s on the valve.Also the top of the valve was beat up. Then I look and I guess what happened was the rocker must of came loose and about cut the stud in half. So I took both heads to the machine shop for inspection and now just waiting for the word back. Not really sure at this point about doing a valve job on the old heads or buying new ones.Will I gain anything with new heads?
Old Jun 17, 2006 | 07:56 AM
SIXFOOTER's Avatar
SIXFOOTER
doing a valve job is a good idea if your going to put the old heads back on. you still need to knoe what the story is on the cam, and you need to find out before putting the heads back on. you can do this with a gauge that is used to measure cam lobe lift.
Anyone got a pic of this thing?
Or, just put in the kit that clutchdust posted.
OR, new heads and all that, downside is more $$, upside is lots more hp to be gained, but more mods will be needed to realise them, like dual exhaust. This is an 81 with the ECM and there is a LOT you can do to wake it up and keep the ecm.
so you need to make up your mind which way to go, just get it back on the road, or serious mod
let us know, be happy to help you spend $$
Old Jun 17, 2006 | 08:29 AM
81vettelover1
Sixfooter, thanks for the info. I guess I better do the new cam cause I dont want to go thru this again. I have done away with the ecm except for the torque converter hook up. I had already changed out the dist with a malloy and went back to non computer rochester carb.
Old Jun 17, 2006 | 08:50 AM
Summerfun's Avatar
Summerfun
This stuff can cost you a lot money if you do it little by little.
Me, I would pull the engine.
Buy a nice crate engine for a sensible price, drop it in and play to your hearts content without fear of more stuff happening.
If you wish to keep the original engine, you can now take it apart in your garage and play with it for a month or ten years whatever pleases you. Build it back to original, shine it up and drink a toast on it every so often while it sits nice and shiny on an engine stand in your garage.
Just my .02
To 81 350 Engine noise
