can someone desktop dyno this for me?
hi, i'm using my brothers SN for this forum, i'm a camaro owner (its a 67) and thought you guys would be the ones to ask about this. i've been to the camaro forums, but they dont respond too quick. thanks
summit stage II 5.7" connecting rods
keith black 10.0:1 pistons
edelbrock performer RPM heads 2.02/1.50 int/exh aluminum
comp cams 268h .477/.480 int/exh lift 224 int 230 exh duration at .050"
edelbrock performer RPM dual plain raised plenum intake
holley 650 double pumper mechanical secondaries
possibly harland sharp roller rockers
hooker super comp headers and 4" side mounts
any suggestions would be appreciated and i'm looking to build a 400 HP streetable engine, i want something basically turn key after i build and tune it. :crazy: thanks for any help.
Re: can someone desktop dyno this for me? (xfactor974)
oh yeah and what do you guys think about putting crane cams lifters with the cam? i dont like the noise that comp cams lifters put out. :cheers: :eek: :confused: :rolleyes:
i had a problem with the file, i dont have anything to open it with :( what #'s did the engine combo turn out? thanks
Senior Member since 1492
What was the result? Care to share?
Looking good :D . 388 ftlbs of torque at the flywheel. Nice. Here's another one for you. That was my brother on my sn. Here's mine. I'm a little curious. Chevy 350 engine, std bore, 8.5:1 compression, Edelbrok Performer manifold, Demon 600cfm vacuum secondary carb, stock heads, hooker super comp headers, 268H Comp cams Extreme energy cam, Also try with a set of 23 degree Trick Flow heads (Aluminum) Thanks for the help.
Re: can someone desktop dyno this for me? (e3pres)
Hey guys! Don't keep us in the dark here. What are the numbers?
Re: can someone desktop dyno this for me? (ddecart)
Ok, combo 1 was for my brother and it made: 388ftlbs of torque at 4000rpms and 360hp at 5500 rpms.
My combo that's on my car now made: 369ftbls of torque at 4000 and 333hp at 5500 rpms. It runs real nice. Next addition..........a BLOWER :eek: :D
1 Post
St. Jude Donor '09
Hey xfactor can you do another one. I'm just dying to know
Sorry its a ford but, I have dumped alot of bucks into this project for towing.
93 460 7.5L
stock heads
Opened intake
3&1/2 inch banks headers and exhaust
9.8 comp ford pistons
crane cam lift .280 int-.295 ex centers 107 int-117 ex @.50 dur.204int- 214ex
93 460 7.5L
stock heads
Opened intake
