Exhaust questions?
Is it more economical to just try and replace the sidepipes and attach them to headers? Or are sidepipes restrictive to letting this big block breathe?
Are there exhaust kits out there that can be bought reasonably that have the hangers and accessories included. If I choose the rear exit I guess I'll be needing some exhaust tips as well. I've only had the car 2 days but would like to tackle this first. Any good vendors that are priced fair someone would recommend?
Thanks,
Scott
For stock style undercar exhaust I would recommend an aluminized system from Allens Stainless Exhaust. Quality, fit, and customer service are top notch. All mufflers through 1972 on stock exhaust had 2" outlets, so I would install a '73 system. All '73s had 2 1/4" outlets.
Also order '73 stainless extensions. Other than size, the only difference is '73 extensions had the pipe in the center and at an angle, '70-'72 the pipes were straight and offset in the extension. If you go with high flow performance mufflers with 2 1/2" outlets, Stainless Works has 2 1/2" extensions. Hanging Vette exhaust can be tricky the first time, but there is plenty of help here.
You'll have to look at the inside of your rear valance to see if the original mounting for the exhaust bezels is there. If not you can cut the hole and make the mounting from fiberglass similar to what is shown below by using the new bezels you will be buying as a mold.
