Problems,crankcase pressure
Old Aug 6, 2006 | 04:33 PM
windsoreight's Avatar
windsoreight
How much boost are you running?
Old Aug 6, 2006 | 06:48 PM
turbovette80's Avatar
turbovette80
I'm only running 8 psi
Old Aug 6, 2006 | 07:35 PM
windsoreight
What are your engine specs(heads, compression, pistons, etc.)? What kind of miles do you have on the motor.
Old Aug 6, 2006 | 09:35 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by shafrs3
Some where you've got intake pressure leaking into the crankcase, possibly through a blown intake gasket.
Blown intake gasket. Very common on turbocharged and supercharged engines. Chevy small block intake gaskets are not originally designed to be pressurized. If it wasn't doing it before and it does now especially at full boost sounds like an intake gasket.
Old Aug 7, 2006 | 05:37 AM
turbovette80
"Blown intake gasket. Very common on turbocharged and supercharged engines. Chevy small block intake gaskets are not originally designed to be pressurized. If it wasn't doing it before and it does now especially at full boost sounds like an intake gasket"
Because it's a pull through turbo does that mean a possible leak would allow the mixture into the crankcase under pressure,Scary!
Old Aug 7, 2006 | 07:18 AM
bashcraft's Avatar
bashcraft
Originally Posted by WESCH
Hi
How does positive crankcase ventilation work into the exhaust ? Do you just route the valave cover line directly into the exhaust ?
Do you keep some kind of a check valve to avoid blow back from the exhaust ?
Isn't the exhaust pressure higher , specially when you run noise dampeners ?
Günther
Like was said, check valves are mounted in the collectors, but these systems are meant to be run with open exhaust. I can't imagine that they work very well, if at all with any kind of mufflers.
Old Aug 7, 2006 | 07:59 PM
shafrs3's Avatar
shafrs3
turbovette80
Either one, blow through or pull through would result in air/fuel mixture in crankcase if leaking past the intake gasket on lifter valley side.
