Continuing saga update aluminum radiator install
#41
Originally Posted by PaulH
This topic has been on my mind since I've been dealaing with my own cooling problems which I think I've solved. My problem now is I think I've overcooled when on the highway and have been trying to find a way to cool a little better in heavy stop and go traffic with the ac on. I'll throw out a few thoughts which may or may be helpful to you.
You mentioned a Summit high flow thermostat...I looked it up on their site and I wonder if it flows as well as a Robershaw / Mr Gasket. Instlallinig the Mr Gasket brand of high flow stat DRAMATICALLY reduced my temperatures. It may be worth a try. Secondly, there are some different brands of fan clutches...is yours really a heavy duty? I've been spending some time on the Hayden web site trying to find a way to get a heavy duty fan clutch on my 71 to improve low speed cooling. According to their site the HD clutch turns at a faster speed than their standard thermal clutch. Its easy for any company to throw the word "heavy duty" on their box, but is it really a quality brand. http://www.haydenauto.com/index.htm
Hope this info is helpful.
ESU
#42
Originally Posted by isosceles
2 things to check: timing and vac leaks. 6-16 degrees is not enough advance. Retarding spark will cause it to run hotter. I tried running without a vac advance distributor, and it would heat up over 220 on the highway. Around town it was fine. You need 36 mechanical advance in before 3000 rpm, then another 10-16 on a vac cannister at cruising speed for 52 total at cruise.
I learned this from forum member Matt Gruber who dyno tunes down here in FL.
Vacuum leaks will make it run lean and hot too.
my car was tnued by Lars last year, carb and dist, timimg is as u say, 16 total, 36 in by 3000, 52 at cruise.
ESU
#43
Originally Posted by tigers123
Take the thermostat out of the equation. Do the boil water to see when it opens. I worked with an old time mechanic who showed me 4 different brand new thermostats that opened at different temps than they were supposed to. Some did not open enough to allow decent flow. So this is important as several other people have stated.
ESU
#44
ESU
#45
Originally Posted by rihwoods
I've boiled some...but now I check thermostat with my Raytek mini temp gun as engine warms up...just by reading stat housing....also use those readings to compare my temp gauge readings....
ESU
#46
Originally Posted by PRNDL
so do you have the dual electric fans installed but not hooked up and operating? I guess they spin on their own when you are at highway speeds, or maybe even the mechanical fan gets enough air going to make them spin. But are they obstructing air flow? If you are overheating at highway speeds I would suspect an airflow problem. How hard would it be to remove the electric fans that you aren't using?
ESU
#47
Originally Posted by Solid LT1
What kind of aluminum H2O pump are you running? The 1984 and later pumps are reverse rotation for serpentine drive belt systems. Maybe your H2O pump is causing problems, I would also say that timing that is not advanced enough will cause overheating problems along with lean fuel mixtures. Have you had Air Fuel Ratio checked? is your timing at least 8 to 10 degrees initial with a decent advance curve? did you get the cooling system filled all the way? (I fill my Vette through the thermostat housing, then mount the Tstat and finish filling the radiator.) One last thought, is the radiator sealed to the support like it was when Chevy built your Vette? If the radiator insn't sealed, air will leak around the radiator and kill the cooling efficency of a Vette.
All new seals from doc rebuild are in the car.
ESU
#48
Originally Posted by BerniesVette
Other than installing dual spalls there should be nothing wrong with your cooling system. I continue to believe it has something to do with your engine. Your timing,as suggested above, could very well be causing all the problem. You didn't say if you had the problem before the engine swap. There are too many people not having your problem with the changes you have made. You will solve it and all will be good!
Bernie
Bernie
ESU
#49
I believe he has a new GM 290 hp crate engine. Not sure how much of the stock emissions crap has been hooked up to the new engine.
ESU
#51
Originally Posted by gerry72
How's the radiator cap? Do you know that it's holding pressure as it should?
#52
wow man it looks like you have covered just about everything! I have nothing to offer you.
I just wanted to chime in and try to dispell the myth that a thermostat won't change the overall operating temp of the engine. It will.
I used a 170 stat with a new alum radiator. Never ever got over 170*-175* (in car guage) even in 100* heat. Ever.
I swapped to a 195 and now it is right under the 200 mark and never budges above that. Of course this is a 1975 l-48 and doesn't produce much power/heat. But the thermostat DID change my operating temp.
#53
1 Post
#54
I realise that you don't want to spend any more dough, but if the oil temperature is your worry, why not install an oil cooler.
I am considering fitting one to my '76. I have a new 383 with no smog stuff, so the carbon canister in the left hand of engine bay has been removed. I am lookking at installing a small cooler in here where air exiting the engine bay via the fender side vent will pass through the cooler first.
This should knock a few degrees off my oil temp, without adding more obstructions to the front of the radiator, or adding heat to the engine bay.
Sounds like you've tried everything else, I admit, my first thought was something wrong with the engine to create too much heat in the first place, but you seem to have addressed all the usual suspects there.
Also sounds like the a/c being on makes a big difference. This can really only be due to the heat from the condenser pre-heating the incoming air and reducing its cooling efficiency once it gets to the radiator. No simple or cheap solutions, but perhaps spacing the condenser further off the radiator would allow more 'fresh' air to access through to the rad.
Best of luck,
Douglas
From normally chilly Scotland, but basking in the high 80's this summer. Hmmmm, global warming, I know its a bad thing, but......
Best of luck,
Douglas
#55
In my opinion, running at 185*-200* is fairly typical. Add a few degrees when A/C is turned on and a few degrees for days when it's above 90* outside. Running 210* on a hot day with the air conditioner on should not be an issue. On a recent cruise driving 70-80 mph with temperatures in the mid 80's and no A/C, my temperture got to a bout 195*. Both C5's I was traveling with were running over 220* without their A/C turned. No one was concerned that their car was over heating or running too hot. From my understanding, a C5 is expected to run over 200 degrees.
#56
Originally Posted by Fevre
You are missing the point, if your car runs at 210, changing from a 190 to 160 stat will do nothing. In your case of course your temp went up when you change the stat since it was operating at a temp lower than the 195 you switched to.
#57
Would it be possible for you to post some pics of your setup. Maybe someone here will be able to spot something we've missed. Is the seal that fits between the top of the radiator and the hood in place?
#59
One difference here: Clutch fan...the older GM thermal clutch fans fully engaged at 190 F....and interesting is they disengaged at around 3500 RPM....
Hayden current clutch fans fully engage at 220 F...and disengage at around 2800 RPM...
Think about what difference that makes...that to me means a "shift" to higher operating temps...
By the way..this info is noted on Dewitts coolingpdf article on his site...and it got my attention..
Rich
Rich
#60
Do not lower your thermostat temp, a thermostat needs to close for the cooling system to maintain a constant temperature. This allows the coolant in the radiator to cool. Your’s is probably staying open all the time. If anything go to a 190.
Put in a 50/50 mix with Water Wetter.
Take the radiator cap off and allow it to reach operating temp to release trapped air.
Put your timing as close to factory spec as possible, make sure it’s not advanced.
I have a Dewitt’s radiator and recently started my hi-performance 350 up after a rebuild. With the engine sitting there being revved it never got above 200. I live in Virginia where it’s hot as he**, the car didn’t run hot before the rebuild. I have a 180 thermostat with a small hole drilled in it to release trapped air. It’s not the climate, the car has a problem. Good luck.
