Steel shim head gasket sealing
While I'm doing my cam swap, I decided to replace my Permatorque .039" gaskets with the .015" steel shim gaskets for more compression. The ones that I will be using are Fel pro with the black rubber coating. They recommend using a sealer, but don't specify what type to use. Any suggetions?
Tom
Tom
Re: Steel shim head gasket sealing (tsw71)
i have the same heads, they have a rough surface. i block sanded mine with 400 for 1/2 hour each. i used the non-rubber Fel-pro .015 with aluminum paint as a sealer.
i assumed the coated type did not need a sealer, but if they say it needs a sealer, they should tell you what to use.
Re: Steel shim head gasket sealing (drives61)
This is where it starts to get confusing. I would agree that a smooth surface should be better for sealing, but I have read articles in the past saying that a slighly rougher surface will bite the gasket and prevent the gasket from moving due to thermal expansion in the heads and block. I like the aluminum paint idea. I bought some copper spray on sealer which should work the same way(I hope).
Has anyone had experience with these coated steel shim head gaskets?
[Modified by tsw71, 1:17 PM 9/8/2001]
i think that is their way of telling you that if u use it on a rough surface it will leak. By not telling u what sealer to use, they are off the hook.
the type of gasket that likes a rough surface is the composition type, not the shim type.
just block sand the heads, in an hour the question will be moot.
Tom
Tom
While I was trying to find out if I needed to use a sealer for the plain (uncoated) shim gasket, I came across a couple of references that said that NO Sealer should be applied to the type of gasket you are installing. I can't remember the references, but I know it isn't from FelPro's "cwappy" website. FWIW, I used that copper spray for my plain steel gaskets. Worked out ok.
There's also a spray on copper coat sealer that works very nice. The big thing though is to be sure that you re-torque the heads after the first few times you drive it. Steel shims have a nasty tendency to leak if you don't.
Re: Steel shim head gasket sealing (dually4wd)
Well guys, I went ahead and used the copper spray on the block side only. I did as drives61 suggested and sanded the heads as well as I could. The head side should(hopefully will)seal well enough to last for a while. The block was not resurfaced during the rebuild years ago so as to keep the numbers visible. For this reason, I decided to use the copper on that side. I can't see any reason why the copper and rubber won't work together, but I've been wrong before. If all else fail, I'll tear it down and do it again. If it does fail, I only hope it will last long enough to get the cam break-in completed.
I can't wait to here this thing run again. This solid cam with the increased compression should make it a bit more fun to drive.
Thanks for the help everyone.
Tom
Tom
Re: Steel shim head gasket sealing (Chuck Harmon)
Do I get a ride when its done? Do I need to wear a watch?
Chuck :cheers:
Chuck :cheers:
Here are the top 4 uses for the watch:
1 Check new 0-60 time
2 Check how long it takes my engine to reach 5500-6000 rpm. (anything under 5 minutes should be considered an improvment) :D
3 Keep track of how long it takes me to pick up various parts off of Hwy 85(rods, parts of crankshaft, main caps,ect.......) :smash: :smash: :D :eek: :eek: :D
4 Verify if tow truck gets there when promised :D :D
P.S. Remind me to tell Steve(Pacin Ca) why I won't be getting his new heads and cam swapped in one day. For some reason, it seems to take me three times longer than before to do stuff like this. I spent over 3 hours installing and degreeing new cam, over an hour putting on timing cover, 1 hour sanding the heads, and 1 hour installing heads. Oh yeah, I almost forgot the 2 hours on the forum durring mandatory break time
hey tsw71 howd you make out with it you get it done yet i use the felpro 1094 .015 gaskets in the circle track motors.. i wet sad the block and heads with 600 and then 1500 use copper spray gasket on head surface and the block surface then assemble retorque once and they seal right up ..we have about 800 laps on the motors and still no leaks.
Re: Steel shim head gasket sealing (pats406nitrovette)
It sounds like you ended up with one heck of a good sealing surface with all of that sanding. I can assure you that my heads are far from being that smooth, but hopefully good enough to work. Many years ago when I was young, I threw a set of 63cc fuelies(462's) on the then stock shortblock. I did this late one night and the only auto store still open had steel shim gaskets only. These had no coating of anykind and I didn't know that I needed to coat them. They worked great for several years and were still good when I finally rebuilt the bottom end. The small chamber heads with the steel gaskets made a very noticable difference in power when compared to the stock castings that came on the car from the factory. Compression is a wonderful thing :chevy
When I get this thing fired up and on the road, I will post an update on the 282S cam, head gaskets, ect....
Tom
