front suspension torque specs
Old Sep 11, 2006 | 08:20 AM
scottw's Avatar
scottw
Default front suspension torque specs
I need the following torque specs for a 1974.
Lower ball joint top nut (Where the grease fitting is)
Tie rod ends
Tie rod adjustment sleeve nuts
Sway bar bushing
Sway bar going to steering knuckle
Idler arm to steering linkage
Thanks for the help.
Scott
Old Sep 11, 2006 | 08:29 AM
Bob Onit's Avatar
Bob Onit
I have the 1973 AIM if somebody doesnt come up with the 74' specs...probably the same
Old Sep 11, 2006 | 08:42 AM
Twin_Turbo's Avatar
Twin_Turbo
they are the same specs
Old Sep 11, 2006 | 12:24 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Tie rod ends
Sway bar bushing
Scott
Ball Joints no more than 65 foot-pounds. Remember that the BJ's and the tie rods are taper fit items so they are held in place by the way they fit in the hole. The nut does not need to be overtightened.
Tie rod ends will do fine with a max of 35 Foot Pounds of torque. Sway bar bushings = tight. No spec on this type of an item is necessary to look up.
Idler to drag link is the same type fitting that tie rods have. 35-40 is enough. Hope this helps.
Old Sep 11, 2006 | 10:40 PM
scottw's Avatar
scottw
Thanks.
To front suspension torque specs
