Dual Spals vrs. Mark VIII = the maddess must stop
#42
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19
Originally Posted by Durango_boy
That would be awesome.
Is it a variable speed controller?
It is off untile 160° than it starts the fan, ramps it to high (to get the fan turning) than it slows to low and ramps up from low to high starting at 160 (low) and topping out at 190° (high). I am runing a 180° T-stat. The advantage is that the electrical system will not see a large amp spike at start-up.
Neal
#44
Originally Posted by BerniesVette
If you use a relay between the controller and the fan there will never be a big amp load on the controller. Just from the alt to the fan.
Bernie
Bernie
Neal
#45
CI 5 & 8 Veteran
Originally Posted by chevymans 77
If you use a relay your fan will be 1 speed and not variable. If I am thinking about this right.
Neal
Neal
Bullshark
#47
Neal
#48
Whats the difference in price between the spal pwm and the dc controller? I think the dc model everyone is using is a hundred bucks or so, what does the PWM cost?
ESU
ESU
#49
ESU
ESU
#50
Originally Posted by PhotoVette1
I've seen them for as low as $59. However, Tom DeWitt mentioned a month ago or so that PWM's had a high failure rate in C3's (though a high failure rate to Tom might be that just one unit failed ). From my own research, I suspect the problem is that C3ers don't hook the fan controller directly to the battery--how can we?! DC Controls sells a capacitor ($10) that allows hooking up the power at the starter--which is the best place in a C3 to hook up a large load.
ESU
#51
I remember Tom's post about the spal failures, one of the reasons I was leaning away from that route. Photovette, I saw you diagram but does your fan work on 1 speed, two, or is it variable. What temps does it come on at etc?
ESU
ESU
I have ordered the DC Controls variable speed controller--they be kinda slow shipping as they make'em one by one. I also have a relay that bypasses the controller in the controller fails.
The car is coming together slowly--I've spent about $2000 in parts overhauling it--so I'm doing it right this time.
#52
CI 5 & 8 Veteran
Originally Posted by sharkman76
The computer for the fuel injection will turn my fan off and on. The chip maker set them for I belive 165 - 190.
Use the money you would spend for a fan controller and apply it to FI. Much better investment. If you don't want to spend that kind of money, set up a simple system using temp sensors that will do the same.
Feedback desired Positive or negative
Bullshark
#53
Photo have you checked your PM's lately?
Bull I used it to dampen the amp spike when the fan starts. The other features are usefull to but I don't have to have them.
Neal
Neal
#54
St. Jude Donor '07
#55
Originally Posted by I'm Batman
Photo, what was the link for their site again? I seem to have lost it.
This it?
http://www.dccontrol.com/
#56
Just a little info I have come across and thought yall may want to know. I have checked with a few of the e-bay sellers on the part#'s of the fans they are selling. About half of the fans are Thunderbird fans these fans look the same but the motors are different. I am still trying to find out the difference in the motors. I think the Mark VIII fans are stronger, I have not verified this but I am working on it.
#57
Good work. I've heard that T-bird fan is what they have in the Taurus's too.
#59
CI 5 & 8 Veteran
The amp spike is only for a milisecond so it shouldn't hurt anything if you have a good relay and circuit breaker.
Bernie
Bernie
Also, if you have a good power distribution / grounding system (wiring), the spike is not going to be anywhere that will hurt anything. True for the dual Spals, I would have to do some measuring for that big honken Ford fan. I run the dual spal fans bang bang in the presense of sensitive ECU electronics with no ill effects.
Also, after reading the data on the dc controller web site, it would have you believe the following:
1) bang bang control of an electrical fan causes wide variation in engine temp as the fan switches on and off.
Not true in my case. only a degree or two at the ECU control point as the fan switches on and off. Those of you that have a the Holley Comander 950 with fan control can run the data acqusition mode and store the temp data over time to verify this for yourselves.
2) Bang bang operation of the fan is noisy and is just not appealing.
Believe me, you don't hear my fans with that 502 RamJet rumbling thru sidepipes.
Bullshark
