What are the advantages of a solid roller????
Old 10-03-2006, 09:42 PM
  #61
63mako
63mako's Avatar
St. Jude Donor '08-'09
Originally Posted by alnukem
OK, I know I'm a butthead & probably will use the solids.......but, what grind would you guys recommend in the hydralic roller? Will I still pull the same power & as wide a RPM power range?????????
Need engine specs, Trans info and rear gear ratio to make a recommendation. With a mild roller (under .550 lift) I think you may give up a few Ft lbs in maybe a 500 RPM or less range with a hydraulic vs solid. If you are looking for every sliver of power a solid my be better but the trade off is more maintainance and shorter life expectancy.
Old 10-03-2006, 09:51 PM
  #62
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Originally Posted by KJL
Here is my combo with a hydraulic roller.
Where did the HP peak, looks like in 5500-6000RPM range ?
I am suprised, possibly getting into valve float or something is going on.
My HP was still climbing at 6500RPM on my 406ci. IF you have race ported heads then the heads should support 6500+ RPM no problem so your HP should still be climbing at and beyond 6000RPM to valve float, can't figure that out.
Also you vacuum is too low for some reason, I have a 242/248 duration and put 10-11" at idle.
Old 10-03-2006, 11:21 PM
  #63
The_Dude
The_Dude's Avatar
St. Jude Donor '11, '16-'17
Originally Posted by Edzred72
Does this thread qualify as one of the longest actual "tech discussions"...with NO nonsense, OT, highjack, jokes, sarcasum, argument, or bashing?????
We play nice when we want to....don't we???
Eddie
STFU n00b.
Old 10-03-2006, 11:32 PM
  #64
kaiserbud
kaiserbud's Avatar
So - this is somewhat in the range you guys are suggesting to ensure no detonation? The 6400 is nice - not that I wouldl visit that...but what concerns me is the memo on 500+ c.u. requirement and a 3500 converter
Grind Number: HR-306-2S-14 IG
ROUGH IDLE, PERFORMANCE USAGE, GOOD MID AND UPPER RPM HP, BRACKET RACING, AUTO TRANS W/3500+ CONVERTER, MARINE PERFORMANCE, 3800-4200 CRUISE RPM, FOR 500+ CU. IN. ENGINES, 10.5 TO 12.5 COMPRESSION RATIO ADVISED. BASIC RPM 3800-7000
Minimum RPM 3000
Maximum RPM 6400
Valve Float 6800
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 13.0 BTDC 51.0 ABDC 109 244 °
Exhaust 67.0 BBDC 9.0 ATDC 119 256 °
Old 10-04-2006, 08:08 AM
  #65
alnukem
Support Corvetteforum!
alnukem's Avatar
Thanks to all you that helped me on this, I learned quite a lot with this thread. I have a low mileage 355 with forged flat tops that I'm stealing off my kid. I am going to order the AFR 180 Competion heads, the Crane Pro Series shaft rockers & go with a solid roller. I was considering doing a complete engine build with a aftermaket 4 1/8" block, but using this engine I can afford to go to a 5 speed with a little more gear this year. I also ordered Comp Cams "Camquest 6" to banter around numbers. Now I need to figure out how many cc head I need to order so I can get this going, it's a 2-3 month wait on the heads! Thanks again!
Old 10-04-2006, 06:03 PM
  #66
Little Mouse
Little Mouse's Avatar
Alright another solid convert Disclaimer if anything goes
wrong with your cam and lifters this message will self destruct in
thirty seconds.
Old 10-04-2006, 06:44 PM
  #67
MotorHead
MotorHead's Avatar
thirty seconds.
I will back you up, five minutes or five miles whichever comes first
Seriously though good move, those are the new design AFR heads ? If they are they flow good, that will be a killer motor
Also if you are looking at the Comp Cams lifters, make sure you get the new design with the roller oiling hole, lots if the old ones around at the jobbers and stores
Old 10-04-2006, 07:23 PM
  #68
alnukem
alnukem's Avatar
Actually, I think I might get a kit off them, I have to do the arithmatic, they will grind it with the 4/7 swap. What "cc" head should I order? I was thinking 64, I thought this would be the right choice running a flat top piston 355 now & when I recover from $$$$$ this year, I think they will be OK for the 377 or 400 shortblock I build next year....what d'ya think??????
Old 10-04-2006, 07:37 PM
  #69
MotorHead
MotorHead's Avatar
64cc, if you think you might go to a 406ci then get the AFR 195's
Old 10-05-2006, 01:05 AM
  #70
Little Mouse
if your going to a 377/406 size motor now is the time to
order the new 195 eliminator head.
Old 10-05-2006, 07:04 AM
  #71
alnukem
alnukem's Avatar
Not a lot of difference, but I was thinking about it.
Official flow numbers on 180s, 195's and 210's:
180 SBC ELIMINATOR STREET HEAD FLOW NUMBERS
INTAKE EXHAUST
.200 138 CFM 110 CFM
.300 198 CFM 158 CFM
.400 240 CFM 190 CFM
.500 260 CFM 207 CFM
180 SBC ELIMINATOR COMPETITION FLOW NUMBERS
INTAKE EXHAUST
.200 142 CFM 115 CFM
.300 203 CFM 165 CFM
.400 247 CFM 200 CFM
.500 270 CFM 217 CFM
195 SBC ELIMINATOR STREET FLOW NUMBERS
INTAKE EXHAUST
.200 137 CFM 110 CFM
.300 194 CFM 158 CFM
.500 270 CFM 207 CFM
.550 280 CFM 211 CFM
.600 286 CFM 215 CFM
195 SBC ELIMINATOR COMPETITION FLOW NUMBERS
INTAKE EXHAUST
.200 140 CFM 115 CFM
.300 202 CFM 165 CFM
.400 248 CFM 200 CFM
.500 280 CFM 217 CFM
.550 292 CFM 220 CFM
.600 300 CFM 225 CFM
210 SBC ELIMINATOR RACE READY FLOW NUMBERS
INTAKE EXHAUST
.200 139 CFM 110 CFM
.300 199 CFM 158 CFM
.400 249 CFM 192 CFM
.500 279 CFM 210 CFM
.550 289 CFM 214 CFM
.600 295 CFM 220 CFM
.650 299 CFM 222 CFM
.700 301 CFM 225 CFM
210 SBC ELIMINATOR COMPETITION FLOW NUMBERS
INTAKE EXHAUST
.200 147 CFM 117 CFM
.300 206 CFM 166 CFM
.400 257 CFM 202 CFM
.500 290 CFM 220 CFM
.550 302 CFM 224 CFM
.600 310 CFM 230 CFM
.650 312 CFM 232 CFM
.700 314 CFM 236 CFM
Old 02-04-2014, 08:42 PM
  #72
bebezote
bebezote's Avatar
If the only purpose of solid roller is to rev to 7500 RPM then I have the wrong cam because I have only been there a few seconds out of hundreds of hours driving. The power band is supposed to start at 3000 RPM, that doesn't mean you have to cruise around at that RPM either, I have over 450 ft/lbs at 2000 RPM. Just because you can rev it to the moon dosen't mean you have to hold your foot to the floor backing out the driveway.
Most of my driving is done at 2000RPM, don''t forget if the solid roller cam makes more power at 6500RPM then it probably makes more power at 2000RPM. For me, personally, I see no reason not have a solid roller in my motor. I like keeping and eye on the valve train, adjusting the lash etc. it is my hobby, if it was a DD and I had to drive it to work I would put a flat tappet cam in it
After building the most radical 502 then 572 blown motors and a blown pantera 351w... and i've had more cam changes than ex wives (a lot..lol).... i've only done either hydro roller or solid roller....never had standard lifter engine...
BUT...i can tell you... if your stroke is not too long... (ie 377ci short stroke 400)... you can not lose with a solid roller.... they are the freaking BEST.... it feels like your engine finally breathes...
peaky, feel wize...it feels like your engine breathes...and revs...
Old 02-05-2014, 12:30 PM
  #73
bluedawg
bluedawg's Avatar
You do realize that this thread is 7 years old right?
Quick Reply: What are the advantages of a solid roller????
