Bolts Stuck - I'm Stumped
Cruising
Need suggestions (tricks) for removing the rear caliper bolts on my '80. I think they have NEVER been removed. Very froze and I've tried WD40.
After reefing on it for 20 minutes I nearly head-butted the rear quarter panel!!
I need help..
I need help..
Put away the WD-40 - Go to your local auto parts store and get some of this. Then let it sit for about 20 min.
http://us.st11.yimg.com/us.st.yimg.c...0_1912_2510737
Advance Auto Parts stocks it in my area.
even better than that is aero kroil
actually creeps up the rusty threads and eats the rust away.
found at eastwoods:
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
found at eastwoods:
found at eastwoods:
found at eastwoods:
Originally Posted by DWncchs
$22.00 a can? I have to have some of that !!!!
buy it from the manufacturer and safe a few bucks.....
www.kanolabs.com
It's by far the best I've ever used
www.kanolabs.com
www.kanolabs.com
If your going to use an impact be careful of the angle.If your not dead on you can round the head in a blink.What works best for me is a 1/2 drive 5/8 sorta semi deep ball swivel socket.Snap-On #IPL20A I dont have many snap-on tools but this is a good one.I keep 3 on hand because I break them and wear them out but return them under warranty..I use it for most of the 5/8 bolts on the car.It seems to be perfect for the rear caliper bolts for all the complications you encounter getting a 1/2" impact in back there in the confined space.
Cruising
Originally Posted by Boofers
Did you put the box end of your wrench on on the bolt and hit the wrench with a hammer?
-R
Originally Posted by fauxrs2
Kroil is the stuff...wd40 is a lubricant... not a penetrating oil
St. Jude Donor '07
Originally Posted by mdj21
actually, WD-40 is a water dispersant. it does pretty good as a metal protectant, but is not a very good lubricant.
I've posted the links too many times, a search for wd-40 or wd40 will turn them up. Long story short...WD-40 is a water dispersant...and a rust inhibitor...and a lubricant.
..... but it's not very good at any of the three.....
How many times do I have to bust this myth?
