***Need advice!! ASAP... with alignment MAJOR PROBLEMS!!!!
Old Sep 15, 2001 | 12:04 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Default ***Need advice!! ASAP... with alignment MAJOR PROBLEMS!!!!
I have really no idea what to do. As some of you know I just rebuilt my front end of my 80. Well I took the car in for an alignment and here are the results.
Left Front:
Camber: -.10 degrees
Caster: +6.50 degrees
Toe: +0.05"
Right Front:
Camber: -.30 degrees
Caster: +6.00 degrees
Toe: .21"
Front Totals:
Total Toe: +.26"
cross camber: +.20 degrees
cross caster: +.50 degrees
The right back side is also an issue but numbers won't matter.
Now the left side of the car can be brought into spec but the right side can't! THey think the car was hit at one point and time and in order to get the car to go right they had to put the left side out of spec.
I need advice on what I should do? Looks like the car took a hit on the passenger side at one point in time. I didn't notice and damge to the frame nor did the shop before I purchased the car.
The shop where the car is now says I can drive it with no problems but I will have shorter tire life.
Does any one know of any place in the northern VA area that I could take this car to?
Is it possible to straighten out the frame if there is frame damage?
The car drives straight and it feels like its on rails in turns.
what to do?
Old Sep 15, 2001 | 12:39 PM
1979toy's Avatar
1979toy
Default Re: ***Need advice!! ASAP... with alignment MAJOR PROBLEMS!!!! (Bluewasp)
Vette Brakes and Products offers front a-arms that they claim offer an increase in the adjustment range of the front suspension. You might take a look at them.
Old Sep 15, 2001 | 12:52 PM
oger's Avatar
oger
Default Re: ***Need advice!! ASAP... with alignment MAJOR PROBLEMS!!!! (1979toy)
Put it on a frame machine that is the only way to check for sure.
Old Sep 15, 2001 | 10:04 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Yeah, I plan on it sometime this week...
Has anyone ever had their vette on a frame machine?
[Modified by Bluewasp, 8:06 PM 9/15/2001]
Old Sep 15, 2001 | 10:36 PM
Bills17n72's Avatar
Bills17n72
Hey is it was me ,I would have everything checked out ,and if it is real expensive to fix, but it is ok to drive, I would go ahead and drive it and not put alot of money in it.
So what if you have to put a set of tires on it every 30,000 miles or so!!!!
Old Sep 16, 2001 | 04:21 AM
Steve Straus's Avatar
Steve Straus
On the off chance that this isn't a Vette shop and doesn't know much about Vettes, have you checked your T-arm bushings? Mine were so worn out that I could wiggle them just about any way I wanted to when the spring and half shaft was detached.
Does your frame LOOK bashed? Usually when a frame's been hit hard enough to cause alignment problems it'll show some sign of damage.
Take your car to Tony's Corvette shop in Gaithersburg. Have Andrew look at it, he is really good.
Old Sep 16, 2001 | 09:39 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Default Re: ***Need advice!! ASAP... with alignment MAJOR PROBLEMS!!!! (Steve Straus)
No, I didn't see any frame clamp marks, weld marks or even the frame having that common crash sign called a "wrinkle".... I need to find someone in my area that has worked on C3s for sure and I need to get laser measurements of my frame to know if its ok.
I also replaced the following on both sides: upper/lower ball joints, tie rod ends (both ends) control arm bushings, new springs, new shocks, new control arm studs, and replaced other rusted out nuts and bolts.. Purchase all items from zip....
robert
[Modified by Bluewasp, 7:41 AM 9/16/2001]
Old Sep 16, 2001 | 09:43 AM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
how bad is it to have your caster at 6 degrees or 6.5 degrees... Its only 3 degrees out of spec.???
Old Sep 17, 2001 | 02:46 AM
glen242's Avatar
glen242
If memory serves, caster does not affect tire wear, only camber and toe in.
My GM spec book for my '76 calls for P 3/4 +/- 1/2 camber, and total toe in of 1/8 +/- 1/32.
Old Sep 17, 2001 | 08:11 PM
Bluewasp's Avatar
Bluewasp
St. Jude Donor '14
Default Re: ***Need advice!! ASAP... with alignment MAJOR PROBLEMS!!!! (glen242)
I am having a frame shop measure the frame tomorrow. NO adjustments will be made to the car. I will post the results either tomorrow night or by next day, mid afternoon.
Robert
To ***Need advice!! ASAP... with alignment MAJOR PROBLEMS!!!!
