Will the AFR 195 Eliminator Comp Heads support a 415 SBC???
Originally Posted by alnukem
I have a couple of stock 400 blocks, but it seems to be a waste to mess with them, putting like $900 in them. I can spend $800 more & have a stronger, more adapted block that can be rebuilt several times. And, a 415 sounds like a humble enough, easy to build combo with some long life. The tech from AFR said it would support it too. I was going to use the super t-10 for a year, but that sounds like a mistake, more ramen noodles to save for a TKO!!!!!!!!!!! What would the reccomendation for main bearing size...........400????????????? I really appreciate your guys input, Thanks!
races at 8900 RPM with small mains and small rod journals. I'm
sure they have at least a 4340 crank or maybe billet but your street
car will be ok with 2.45 mains.
I have the 350 main 427 ci (4 inch stroker) standard deck Motown and an extra 350 main 415 ci (3.875 stroker) rotating kit.
The 350 main cranks are a couple of pounds lighter and the saddle/main caps are thicker. So for higher HP I would use the smaller 350 main size.
I'm not sure why anybody would go with the lower ci 3.875 when the cost is the same. I did not want to reduce my 427 ci on my last rebuild because of my Wiseco 415 pistons had the same 20 cc dish which would lower my compression even more. I think that you will find that all the 415 rotating kits are lower compression
I am going to look at a brand new 4340 Eagle crank 4 in. stroke, 400 mains this Friday, not alot of pistons to choose from to keep it on pump gas but Mahle makes one, dished -20cc that puts me at 10.5:1 with 64cc heads
Sorry about the hijack alnukem, it is a good thread though
Sorry for bringing a dead thread back to life after a decade, but I finally finished my build & in the sake of providing information for people searching for results, I am providing them, as there wasn't much info when I was looking.
Basic Build;
4.125" Dart SHP Block with 350 Mains
AFR 195 Eliminator Competition 75cc Heads with heat crossover
Callies Compstar 3.875" Crank
Scat 6" Pro Mod Rods with ARP 2000 bolts
530/530 @ 230/238 with a 112 lobe Hydraulic Roller(It was actually spec'd for a 396 SBC)
Weiand Stealth Dual Plane that was Exude-a-Honed to match the Ports
Barry Grant 650 CFM Mechanical Secondary Carb
Moroso Stroker Pan
Not a lot of Machining of the Pan rails with these rods.
On the Engine Dyno, the results are
560 Peak HP @ 5900
583 Peak Torque @ 4500
Ought to be a good street Engine, which is what I was going for. I know the Cam is too small, but it was paid for! Thanks!
Basic Build;
Moroso Stroker Pan
560 Peak HP @ 5900
Yeah, life got in the way........Parents got ill & finally succumbed, the Family business was in the Crapper! 10 Years of 80 hours a week & not much left of me after that. I am glad I have a little recreational time now. Thanks for the comment.
