A New problem with the diff - HELLLP!!!
Old Nov 7, 2006 | 11:42 PM
genuine1980's Avatar
genuine1980
Default A New problem with the diff - HELLLP!!!
I have the diff down so replace the snap rings and Seals.
Was cleaning the inside when I noticed a possible problem.
It looks like there is a steel spacer between the carrier bearings and the side of the differential case. It looks like the spacer on the pass side is cracked.
I have no experience working on differentials. As I said above the work I was going to do was simple and did not require taking the carrier out.
What is this spacer called? Where do I get one? How hard is it to take the carrier out to 'just replace the cracked spacer'?
EVERYTHING else inside looks nice and clean.... no signs of wear. Besides the need to replace one of the snap rings, the diff was working great at the time that I took it down out of the car.... posi was just fine.
Old Nov 7, 2006 | 11:46 PM
wombvette's Avatar
wombvette
They are actually shims. They are used to set the bearing placement and preload. What you see may be two shims and you are seeing the line between them.
Old Nov 7, 2006 | 11:51 PM
genuine1980
I actually don't see any shims.
This appears to be a solid metal spacer that is between the side differential case and the bearing for the carrier. (One on each side).
Old Nov 7, 2006 | 11:58 PM
genuine1980
Could it be just one... really thick shim?
Since I have no clue how to post a pic on here... I can send it via email
Old Nov 8, 2006 | 12:25 AM
genuine1980
Ok figured out how to get a pic...
If you click on it it will be larger and you can see on the right side of the carrier bearing, there is some spacer and it is clearly cracked.
Old Nov 8, 2006 | 01:40 AM
wombvette's Avatar
wombvette
Yes the factory used thick shims of the correct size when they assembled them. I am sure that was easier than stacking a bunch of shims. I see what you are talking about. I am not sure that it is really a crack, maybe? I have seen them with marks like that before. Even if it is, I dont see how it is a problem though. That thing is wedged in there fairly tight and there is no where for it to go. I dont think that I would worry about it. If you replace it, you need to mic it and replace it with the same thickness of shims.
Old Nov 8, 2006 | 06:36 AM
Gordonm's Avatar
Gordonm
Oh that is cracked. They use cast iron spacers from the factory of the correct size they needed. To replace it you would have to remove the carrier and mic up the broken spacer. get a shim kit and replace it with the correct number of shims. You would need the same thickness as the one big spacer. Not really a big deal. But now you have the carrier out I would replace the clutch pack. Welcome to the While your at it syndrome of owning a C3. What was going to be an easy job turns into a body off resto.
Old Nov 8, 2006 | 08:25 AM
GTR1999's Avatar
GTR1999
Those are cast iron shims, ground to size at the factory. They are not reused during a rebuild because
1- They break.
2- The size changes during rebuild
They are under "load" as these preload the carrier bearings. You may get by if you change the exact size steel shims per side but I would run a pattern check before and after. The carrier should be under enough load that it will not slide out. You have to put a bax wrench on a ring gear bolt and turn the pinion until it walks out. Stamp the bearing caps L&R before so you return them to the same location.
Old Nov 8, 2006 | 10:25 AM
genuine1980
1- They break.
Thanks for your replies!!!
Now I'm sure a lot of you are going to upset to what I'm going to say
But since it is indeed just a spacer, and since it is under a load and will not come out by itself...
I am going to stick to my original plan and just replace the snap rings and outer seals.
Like I said I have no idea how to rebuild the diff... clutch pack, bearings and all that. Aside from the yoke sliding ina and out because of a broken ring, the diff and the posi were in perfect working order when I removed it. After cleaning the inside of the case with brake cleaner, everything looked new, with no sign of wear (besides the cracked spacer).
Thanks again
Old Nov 8, 2006 | 06:50 PM
GTR1999's Avatar
GTR1999
I can't tell if that is a crack or not. They usually don't break unless someone tried to hammer them in while installing them back.
That is an early diff as it has the full radius bearing caps, the later caps have a tab cast into them. Does it have the little sq rear window or the large tear drop one?
Did you find the snap rings? Bair in your home state should have them.
Old Nov 8, 2006 | 10:43 PM
genuine1980
It is def a crack as I can feel it with my finger and put my finger nail in it.
I don't know how to tell if it is an early one or not... I dont know what a bearing cap is, but it does have the little sq window in the back of the carrier.
Thanks again
Old Nov 9, 2006 | 07:57 AM
GTR1999's Avatar
GTR1999
The bearing caps are where the bolts go through to hold the carrier in the case. The small back window carriers were the early ones used up to mid '69? Look it over good, they tend to crack more then the later units. Look at the edges of each window for small cracks forming.
To A New problem with the diff - HELLLP!!!
