SS Calipers - How do I know?
Old Nov 9, 2006 | 03:33 PM
Vette Set's Avatar
Vette Set
Default SS Calipers - How do I know?
Is there a way to tell if the calipers have been SS sleeved without taking them apart? Even then, what should I look for? My experience with disc brake calipers is that inside of the cylinders have a very shiny machined appearance. Anyone have close-up pics of a sleeved caliper?
Old Nov 9, 2006 | 03:35 PM
Scott Marzahl's Avatar
Scott Marzahl
On the outside, some vendors like Vette Brakes for example stamps a serial number on them. Once apart it is very obvious that a sleeve is in place. You can see the stainless ridge against the cast housing and in the bottom of the hole you can often see the machined cut.
Old Nov 9, 2006 | 03:39 PM
Twin_Turbo's Avatar
Twin_Turbo
a sleeved caliper has a very distinctive "step" in the bottom, you can see where the original caliper was machined out and the sleeve pressed in, there's a parting line that's very visible.
Old Nov 9, 2006 | 03:50 PM
Vette Set's Avatar
Vette Set
Thanks, guys. I think my right rear caliper is leaking a little and if I have to do the brakes, I may as well have the calipers sleeved at the same time.
To SS Calipers - How do I know?
