02 sensor for A/F
Old Nov 29, 2006 | 11:06 AM
Hvymtlc5's Avatar
Hvymtlc5
Default 02 sensor for A/F
Sounds like something I need to optimize the engine tune. Question is: do I need two A/F gauges to read a sensor in each header or is there a switch unit..how does this setup normally connected?
Old Nov 29, 2006 | 01:02 PM
SIXFOOTER's Avatar
SIXFOOTER
you only need one
Old Nov 29, 2006 | 03:11 PM
Hvymtlc5's Avatar
Hvymtlc5
How does it work feeding two inputs into one guage unless I use a switch??
Old Nov 29, 2006 | 03:34 PM
Gordonm's Avatar
Gordonm
You only need one sensor in one header or collecter. Both sides should be pretty much the same.
Old Nov 29, 2006 | 06:04 PM
Duke94's Avatar
Duke94
Actually, if you want to set the idle screws, you need one in each or at least 2 bungs. I bought the adaptor that clamps to the tailpipe and I switch from side to side. It works very well, but wasn't cheap (75 bucks for the clamp deal.) Plus I can use it on other cars.
To 02 sensor for A/F
