Rack & Pinion Steering
Old Dec 11, 2006 | 06:08 PM
worship79's Avatar
worship79
Originally Posted by Twin_Turbo
the only criterium for that rack is, rear steering center take off GM rack...and that rack is the most common. The original concept came from a norwegian guy called ingar (wasn't his username ingar norway?) and he used this rack because n norway it was easy to get a hold of since it's also used in opels and saabs. It's not just the 92 rack, other years & models will work just the same.
Opel and Saab you say? So it should be pretty easy to get by in The Netherlands as well, right?
Old Dec 11, 2006 | 06:14 PM
Twin_Turbo's Avatar
Twin_Turbo
yeah...I think it came on the early 90s vectras but you can also order a recon rack online, there are plenty of rack rebuilders that offer the rack you want. Do you want R&P? If you can cut, measure and weld and have a basic understanding of bumpsteer geometry it's very easy to build it yourself.
