75 with true duals?
Old Sep 24, 2001 | 11:43 PM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Default 75 with true duals?
Looking to put true duals on my '75 L48. On a related note, also thinking about headers. I know you're not supposed to, but would a '74 exhaust fit on my '75? The only difference is the cat convert, right? Should I look for new mufflers too? Also wondering how difficult it is to convert to duals and what type of performance boost to expect.
Old Sep 25, 2001 | 12:18 AM
OldSlowVette's Avatar
OldSlowVette
Default Re: 75 with true duals? (Buffalo Dude)
If you are operating strictly "off-road" then a 74 exhaust system should fit and be legal.
You will be very pleased with the results
Old Sep 25, 2001 | 02:12 AM
tnt76vette's Avatar
tnt76vette
You wont be sorry...I truly believe I gained just as much of a boost with my true dual chambered pipes as I did w/my cam/intake change.....now runs like a Vette and sounds like a Vette...and that makes me :D :D :D tnt76vette
Old Sep 25, 2001 | 02:22 AM
krafty79's Avatar
krafty79
Default Re: 75 with true duals? (tnt76vette)
ceramic headers from Jegs - $205
local exhaust guy to weld 2 1/2 pipe under the car - $120-$150
10" glass paks - $20
3" chrome tips out the back - $22
total - $365 - 395.... lotsa h.p. gained
tried 4 different mufflers but could not tolerate thier unique sounds... the glass packs placed at the end of the exhuast pipe just prior to the tips give a true throaty rumble, no tinny sound or crackel.. just grunt!
Good luck.
Krafty
Old Sep 25, 2001 | 02:03 PM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: 75 with true duals? (krafty79)
I went with Hooker's true dual pipes, headers & chambered mufflers. Everything fit great and runs great and I like the sound. Look up the part numbers from their web site. I bought everything thru Summit.
Old Sep 25, 2001 | 02:05 PM
Alwyn678's Avatar
Alwyn678
Wow 10 inch glass packs for 20 bucks...I may have to try those bad boyz
Old Sep 25, 2001 | 03:15 PM
Racer-X's Avatar
Racer-X
Default Re: 75 with true duals? (Alwyn678)
I bought the ceramic coated headers from Jeggs $200.00
I'm having local muffler shop install duel pipes to the back $325.00
Same muffler shop charging me $90.00 for a pair of turbo mufflers, installed.
headers installation $250.00. It took them about 6 hours.
Total cost=$865.00
I'm getting the car tomorrow.
:flag
Old Sep 25, 2001 | 04:45 PM
Go Ravens's Avatar
Go Ravens
Default Re: 75 with true duals? (Racer-X)
Dynomax coated headers $190
Flowmaster 40s $55ea - $110
Local Exhaust shop fabricated and welded it all together with 2.5" pipe. $325
They also removed my old manifolds and put the headers on $240 (I couldn't get the manifolds off!!)
Old Sep 26, 2001 | 09:59 AM
KenSny's Avatar
KenSny
Total cost=$865.00
Damn that's a lot of money for an exhaust system......
Old Sep 26, 2001 | 10:51 AM
Racer-X's Avatar
Racer-X
Default Re: 75 with true duals? (KenSny)
Yes that is alot of money! I did not spend the $860.00 all in one time but in incraments so it did not hurt as much. I was planning on doing most of the work myself. I ordered the headers, after I got the headers I noticed all the manifold bolts were rusted on so I decited to have them installed at a place that can deal with broken studs and redoing air conditioning brackets. I then brought the car to Minekie and they quoted me $300.00 for the duel pipes. then I heard some ones duel pipes and they sounded pretty loud. So I had minekie install small turbo mufflers.... So the expense was not anticipated. If I knew it was going to cost so much I would have waited another year. But I kept getting myself deeper and deeper to the point of no return. But all in all It had to be done because the old pipes were leaking so it was do it now or do it later.
:flag
Old Sep 26, 2001 | 12:47 PM
tnt76vette's Avatar
tnt76vette
Chambered Pipes from Mid Am 299.99. Local muff shop installs: 120.00. 420.00 plus tax....sounds like I saved abt 400 bucks... :D :D :D :flag
Old Sep 26, 2001 | 06:11 PM
krafty79's Avatar
krafty79
Total cost=$865.00
:flag
Racer, had the same set-up at first, then took the mufflers off, too damn quiet for me... please let me know how yours sounds?
krafty
Old Sep 29, 2001 | 12:49 AM
Buffalo Dude
St. Jude Donor '07
Thanks guys. Just a couple more questions:
Can I do this myself in a weekend? Should I be doing this by myself?
What about gas mileage?
a)better
b)worse
c)it's cheaper to launch the space shuttle, but holy s*** it's fun when you drive it!
It's now on my list of things to get, right after a new radiator and new tires :D
Old Sep 29, 2001 | 01:55 AM
Captain Morgan's Avatar
Captain Morgan
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Maybe you saved 400, but you didn't get the headers. I plan on getting headers ($219 now), better gaskets, locking bolts, etc. (app. $85), and then I still have to get the pipes and mufflers (haven't priced them yet). It all depends on what you want. I'm sure the chambered pipes sound sweet but I don't really want mine that loud.
Old Sep 29, 2001 | 02:12 AM
tnt76vette's Avatar
tnt76vette
Default Re: 75 with true duals? (sharklover)
Think of it this way friend; the only time they're LOUD is when I want them to be...they really are great for cruisin too as a conversation or listening to the radio is no problem... :yesnod: :flag
Old Sep 29, 2001 | 12:28 PM
BubbaJJ's Avatar
BubbaJJ
You could always maintain the intent of the emissions stuff and put a cat behind each bank.
Old Sep 29, 2001 | 12:45 PM
Captain Morgan
Cruise-In V Veteran
Default Re: 75 with true duals? (BubbaJJ)
Really? Hmm, maybe I'll have to consider them. The only problem I find is that they are designed to bolt up to the manifolds and I want to install headers. Not sure how much extra cost would be involved to have them cut off so they would fit the headers. I'll have to do some research.
While you would maintain the intent, it would still technically be illegal (not that what any of us are suggesting is legal anyway). According to the stupid laws, you can only replace what was originally on the car from the factory, you can't add to it and you can't remove from it. If it had only one cat, you can only put on one cat. To be completely legal and still get some decent performance, you would have to go to a larger pipe where the two meet up, stay with a large hi-flo cat, and then split the pipes again to go out the back. Stupid law. :rolleyes:
Old Sep 29, 2001 | 01:35 PM
daniel77350's Avatar
daniel77350
depends on the state. Some just say you need a cat(I can't remember exactly how its wored). Somewhat of a loop hole I think. But it basically means if you have seperate pipes, you can have 2 cat's. It would seem dumb to me that they would force you to use a 2-1-2 when duels with a cat on each is just as effective(at least I think it is).
Daniel
Old Sep 29, 2001 | 05:14 PM
chevyman's Avatar
chevyman
I went with Allens chambers with my 75 but I didnt use headers. It bolted right up to the manifolds and you cant beat the sound. I heard of many people that didnt have luck with Allens exhaust with headers. Took about three hours to remove/replace. Good Luck
To 75 with true duals?
