Brake Dilemma
Old Jan 21, 2007 | 02:04 PM
Doug Maitlen's Avatar
Doug Maitlen
Default Brake Dilemma
I recently started replacing all my brake pads on my 79. I started on the passenger side and ran into trouble. The front wheel went smooth and the pads looked slightly worn, but as I started on the passenger rear, the difficulty started. As I took the old pads out, I noticed that they looked burnt. What caused this? Is it something I should be worried about?
Old Jan 21, 2007 | 02:07 PM
Duke94's Avatar
Duke94
Can you post a picture? Sounds like they may be dragging. If the hoses are original, it would be money well spent to replace them. They will come apart on the inside causing a fluid flow restriction.
Old Jan 21, 2007 | 02:08 PM
Durango_Boy's Avatar
Durango_Boy
The car's been rode hard and braking conditions were not optimal. Also cheap pads. I would suggest...since safety comes first...pull all pads and all rotors. Have all four rotors turned to delete runout, and buy a new set of pads for both front and rear. Higher grade for front, and basic pads for back. Then once all your wheels are back on, check for bearing wear, or tie rod wear.
Old Jan 21, 2007 | 03:59 PM
Big2Bird's Avatar
Big2Bird
Old Jan 27, 2007 | 01:44 PM
Durango_Boy
It's also always a good idea to replace flex hoses, and if it's in the budget, spring for the S/S braided ones. They are much stronger and will last...and look better too.
To Brake Dilemma
