82 Fuel system question
Old Jan 23, 2007 | 08:04 PM
noonie's Avatar
noonie
Nice setup
What size your retrurn to tank line?
Old Jan 23, 2007 | 11:01 PM
Clint's C3's Avatar
Clint's C3
Originally Posted by noonie
Nice setup
Thanks. I don't really like the look of the rubber hoses and plan to replace with braided lines and AN fittings at some point. I tied into the original supply and return lines, I think the return is a 5/16", routed in front of the motor.
Old Jan 24, 2007 | 08:02 AM
rsvette82's Avatar
rsvette82
Does anyone know where I can get a used or wiring harness for the crossfire injection. I am curious what one would cost.
Old Jan 24, 2007 | 09:45 AM
jdp6000's Avatar
jdp6000
You sure the harness is all gone? Passenger side fire wall has a black box. Inside there should be 3 or 4 or more plugs. Most disconnect the wires that supply the engine compartment and crossfire there. From there those wires go into the cab of the car and back to the computer in the battery compartment.
Jim
Old Jan 24, 2007 | 10:03 AM
Durango_Boy's Avatar
Durango_Boy
Check first. Most likely, unless the previous owner removed it to sell with the crossfire, it's still in the car.
Old Jan 24, 2007 | 10:12 AM
markdtn's Avatar
markdtn
Ebay, used Corvette parts places, might even try www.junkyardog.com or www.car-part.com
Also might try Corvettemack, he has stuff on Ebay all the time.
Old Jan 24, 2007 | 10:31 AM
rsvette82's Avatar
rsvette82
Sorry, I should of been more specific on what I was looking for. I have all of the wires from the inside of the car to the firewall but I do not have the harness that connects the 4 plugs by the firewall to the crossfire unit on the engine.
Jim
Old Jan 24, 2007 | 10:40 AM
Durango_Boy
Download a wiring diagram for that section of harness that you don't have, and make your own. It's not that hard so long as you can get the plugs.
Old Jan 24, 2007 | 11:58 AM
rsvette82's Avatar
rsvette82
I do have a picture that someone sent me of the harness and your right - it does not look like it would be too hard to make a harness. Where could I download the wiring diagram?
Old Jan 24, 2007 | 12:34 PM
markdtn's Avatar
markdtn
You could buy a shop manual, that would have a good diagram. Probably could use a TBI harness from most any period GM TBI car and adapt it to make it work. 87-95 truck/suburban, 87-92? Ciera, Century, Celebrity, etc. if you can't find an 82 harness.
Old Jan 27, 2007 | 02:37 PM
Durango_Boy
I'll bet the '82 harness will be very available on Ebay and other used part listings.
