Dual mount rear spring question
Old Jan 26, 2007 | 11:51 PM
69 Vette's Avatar
69 Vette
Default Dual mount rear spring question
So i take it you no longer use the center mount on the differential?
Old Jan 27, 2007 | 12:29 AM
JPhil's Avatar
JPhil
Correct. Spring is no longer mounted there. Two brackets bolt onto the frame cross member and spring mounts to them.
John
SlixVett's Avatar
SlixVett
Correct - the two mounting brackets attach to the rear crossmember outboard of the differential. The crossmember must be drilled for the bracket mounting bolts - don't know if it can be done while in the car; mine was out.
Old Jan 27, 2007 | 09:07 AM
69 Vette's Avatar
69 Vette
Okay good i got it right then
Yes, i had to remove the rear cross member to drill it.
Thanks guys!
Old Jan 27, 2007 | 09:09 AM
Gordonm's Avatar
Gordonm
I just did mine two weeks ago. I did pull everything out and it made it very easy. It can be done in the car but you still have to drop the crossmember some so you can drill the holes. It is not that hard to get it out and you can clean and check other things while it is out.
To Dual mount rear spring question
