timeing tape
Old Feb 27, 2007 | 07:20 AM
dmaaero's Avatar
dmaaero
Default timeing tape
When installing timeing tape on the hermonic balancer does it go clockwise or counterclockwise around the balancer?
Old Feb 27, 2007 | 07:42 AM
SIXFOOTER's Avatar
SIXFOOTER
There should be a zero on the tape that should line up on the timing mark and wrap both ways from there
Old Feb 27, 2007 | 07:45 AM
Twin_Turbo's Avatar
Twin_Turbo
get a marked cover, the tape is worthless
Old Feb 27, 2007 | 08:15 AM
dmaaero's Avatar
dmaaero
hay twin i have a marked cover, I'm just trying to find 32* so i can set the timing while the cams breaking in.
Now i could just get a adjustable timeing light, but the tapes much cheaper! I just need to know what side of tdc to put the 32* mark on
Old Feb 27, 2007 | 08:38 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Put the tape on the balancer so the numbers are right side up when you are reading them from the drivers side of the motor...........
TT is talking about the degreed cover that fits over the balancer...much better than tape....
Old Feb 27, 2007 | 08:39 AM
stingr69's Avatar
stingr69
To the right of zero on the balancer. 1/10 of the circumference is 36 degrees. That is where I would put the mark.
-Mark.
Old Feb 27, 2007 | 09:10 AM
dmaaero's Avatar
dmaaero
oops, sorry twin, i guess i don"t have a marked cover then! I'll have to check into that cover. I never seen one before.
Old Feb 27, 2007 | 09:36 AM
Twin_Turbo's Avatar
Twin_Turbo
30$ or so from summit
Old Feb 27, 2007 | 03:03 PM
7T1vette's Avatar
7T1vette
If you don't want to spend the $30, use your mechanics rule to measure the actual distance [on your timing scale] between the 0 mark and the 12 degree mark. Multiply that value by 3, then place a mark that distance away from the TDC line on your damper in the CW direction. That will be very close to the 36 degrees you are looking for. You can judge each way a few degrees using the scale distance on your engine for reference. If you permanently etch or scratch the 36 degree line on your damper, you can use it in the futurer, if you need.
To timeing tape
