Will an oil cooler really lower engine temp.
CIRCLE TRACK Magazine
"In fact, as high as 95% of engine wear occurs in the first 10 seconds after startup before oil has pressurized and coated bearings and other critical parts."
Fall '98 issue DIY BOAT OWNER
"Significant engine wear can occur at start-up, so it’s critical for engine parts to receive proper lubrication as soon as possible. Prior to start-up, most of the oil resides in the engine’s sump. When the engine is started, a short period of time elapses before the oil can be pumped from the sump and supplied throughout the engine. During this critical time, engine parts are not adequately lubricated."
Mobil 1 brochure
"There is clear evidence that most of the engine cylinder and ring wear occur when an engine is started up from a cold condition, and at the location on the stroke where the lubricant film is least well-established, at the hot end of the cylinder (top-dead-center)."
A Review of Sub-Scale Test Methods to Evaluate the Friction and Wear of Ring and Liner Materials for Spark- and Compression Ignition Engines November 2001
"More than 75 percent of engine wear occurs on startup and shutdown."
Fleet Management: Vehicle Rotation Criteria.(Law Enforcement Agencies) From: The FBI Law Enforcement Bulletin Date: 8/1/2002 Author: Exley, Curtis W.
How to Make Your Car Last Twice as Long, David Solomon
"Most engine wear occurs immediately after a cold start, so it’s important to have oil that is thin enough to circulate easily -- especially at cold temperatures."
What type of motor oil is best for my engine? Yahoo Autos
"90% of all engine wear occurs on cold start because the oil gets thicker the colder it is - which causes engine wear."
Drivers Technology Ltd
"Because most engine wear occurs at start-up, the faster the oil can be pumped to all the moving parts, the better."
www.rislone.com
"Typically, it takes several crankshaft rotations to pressurize the oil galleries at start-up, and until then, the engine has minimal, if any, oil film protecting the surfaces. Independent studies attribute as much as 90 percent of engine wear to cold-start scuffing."
High Performance Pontiac
it's a group of related iussues and one push the other toward a single direction: to arrive to a single temp figure, of course this never happens because the 'sistem' is unstable in its temp (could go and down) along the time...and all the factors which determines it fluctuate quickly.
in a phisical 'perfect' sistem creating heat, the heat will be equal in all its parts, on the long run, if the variables keep constant through the time...
...and now i have to go to work
Panic has a good understanding of basic physics
SAE has also many years ago established that roughly 60% of the gasoline engine is cooled by the oiling system and 40% by the coolant system. Oil cooling is important to say the least. It does more than just lubricate.
Adding an external cooler though, in most cases is not necessary. The sustained use thru higher rpm or increased workload can put the oil over it's design temperature, and lose it's film strength and cause the metal to metal contact that destroys moving parts. Generally oil in the pan and read by a sump sensor may only show a crude average of 200°, but the oil at the rod end bearing may be at 300° thus degrading that oil. Once the majority of oil has been "burnt" so to speak, then it quickly loses it's lubrication qualities and the engine will suffer quickly. Sensors thruout the critical areas of the engine are impractical so educated prevention is the only resource.
So understanding that a lot more than just engine cooling is a concern, keeping the oil itself in good shape would benefit by an additional oil cooler, although not mandatory. As with synthetics, you will be able to slightly increase oil change intervals.
The hot new type of cooler is a Laminova, a liquid to liquid cooler, with such a great novel design, that GM amongst, other leading makers are adapting them to engine use in their new product lines. They have long understood their importance, it is that just now it has become practical and economical.
well, ehem...it's the result of my studies in thermodinamic during my first biennal course at the university
It takes a real engineer to determine what is truely required and beneficial. Anybody can come up with an "overkill" solution.
Bernie
No need to bash me for how you feel about something I am doing and because you don't agree. It's all your opinion, and judging or bashing me based on that's a tad uncalled for. Very assuming and judgmental.
Think of the engine, running at a certain condition, as a fixed heat source with a variety of interconnected and parallel heat sinks/outflows to ambient - By adding an oil cooler you are changing the balance, connection and even the direction of those flows.
If your oil cooler is oil-to-air, then you are rejecting a certain amount of that combustion and friction heat to ambient - this is the case where you might argue the OC has the most potential to influence running temp.
If you have an oil-to-coolant type cooler, then some of the oil heat is being re-directed back into the coolant flow, to be dumped out in the radiator. Since the coolant flow is thermostat controlled, this setup is unlikely to influence the engine temp (if by "engine temp" you mean coolant temp, which I guess you do)
Which medium, oil or coolant is the most influential in setting engine temp? Well, which medium picks up the most heat? An earlier poster said
"SAE has also many years ago established that roughly 60% of the gasoline engine is cooled by the oiling system and 40% by the coolant system. Oil cooling is important to say the least. It does more than just lubricate."
which I'm assuming is talking about the surface areas that the oil and coolant respectively see. That DOESN'T mean that 60% of the HEAT goes to the coolant though - it's a much higher percentage than that. I don't have any actual rig numbers in front of me now but off the top of my head I'll say 90% or more of the engine's total wasted heat (combustion and friction) comes out in the coolant.
The oil's just not influential enough in the overall picture to permit an oil cooler to have a major influence on engine temp.
I agree with the general consensus that it's probably not useful to install an OC unless you're seeing high rpm and low speed ( = low radiator air flows) ie racing.
I'm dyno testing a turbo diesel engine at the moment, which uses oil jets to cool the underside of the piston. This is a case where an oil cooler DOES have a use, because it's there to pull out all that heat from the oil which it picks up from the pistons.
And since we seem to have opened up a debate on whether it's warmup or startup that causes most wear, well, it's mostly startup. Once you've built pressure, the bearings should be seperated by a film of oil. The piston sees the same film effect at midstroke, but will always see a degree of metal-to-metal contact at either end of the stroke, because its speed isn't sufficient to build up the wedge of oil into a film.
Durango, if I were you I'd take some oil temp measurements first before fitting a cooler.. then it's as simple as:
Oil too hot = fit a cooler
Oil ok = don't fit a cooler
Cheers
Theo
cooling oil isn't the true problem! but volume of oil yes!
because with 5L (quantity of oil in a V8), in europe we use 5L of oil for a 2L engine (2L=122ci)
more rpm, more oil you need (no true for dry oil pan lubrification).
2L engine in europe rev more than a V8.
so as long as you have "few" oil you need to check oil temp!
hopes this help !
Durango--> i'm intresting to swap my clock to a oil temp, how do you do this?
Yep, you and I seem to agree! Again, I wish I had some easily accessible heat numbers to share (can't really be bothered to trawl through my data!) but the amount of heat moved by the coolant is many times greater than that removed by the oil, therefore any system which provides an extra heat sink FROM the oil (ie Oil-to-air OC) will only have a minimal effect on the engine temperature.
In the diesel I mentioned above, the OC's mainly there because we're using piston cooling oil jets, and you therefore NEED to provide a means of getting that extra oil heat input OUT. Now that heat goes off to the coolant, via the oilcooler, so you could actually think of it as having water cooled pistons, but with an oil "buffer" transporting the heat from piston to coolant. Which is good because I don't think water jets inside the engine are a very good idea
Come to think of it, I think big old ship diesels sometimes had water cooled pistons - imagine that!
Anyway, the point I'm trying to make is only fit an EOC if your oil temps tell you that you NEED one.
