LT1 clutch bolts
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
I looked up info in my ARP catalog.
Need to know your bolt size. Can you measure it or do you have an old one for reference?
Here is the 4 bolts that they list for Chevrolet;
9/16" head size - 3/8-16 thread - ARP High Perf # 130-2201
Tilton flywheel and 3 disk AP clutch - 5/16-24 thread - ARP Pro #330-2202
Tilton flywheel (1.50 UHL bolts) - 5/15-24 thread - ARP Pro #330-2203
LS1 & LS6 Gen III 4.8,5.3 & 6.0L - M10 x 1.50 - ARP High Perf #134-2201
Try Summit or JEG's for ordering.
Hope this helps
Dennis
thanks for reply! i find this
so i must find this!
-GM Pressure plate bolts, PN 10079898. Youll need 6 of them. ARP doesnt have them as far as I can tell. Reg ol Gen 1 and LS1 only.
Youll torque these to 30 ft lbs.(thanks JeffVette) Again I used red loctite. Tighten down in stages...
Do NOT use any other type of bolts (harware fully threaded type)unless you dont appreciate your legs in one piece. You can only get these from the dealer as far as I know. Maybe Pioneer makes some, I didnt check with them
i don't understand!
http://web.camaross.com/forums/showthread.php?t=505301
so standard ARP bolt for pressure plate will work!?
HELP !!!!!!!!
HELP !!!!!!!!
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
1 Post
i don't understand!
HELP !!!!!!!!
HELP !!!!!!!!
Yes sir
