Making a C3 up to par with a modern sports car....Discussion maybe?
#41
St. Jude Donor '07
#42
can I tell you a secret?? promise not to tell anyone?? OK!! don`t tell anyone but extending your spindle or running a longer ball joint is a bunch of BS...my ball joints are standard Corvette right out of a MOOG box, my spindles haven`t been welded on and I run a factory size front sway bar..... remember you promised!! ...redvetracr
#43
St. Jude Donor '07
I know your combination now Except the front spring rates
But did you fix your bump steer? Did you modify your center link? Or just drop the outer tie-road.
Sixxpacker is that you
I Just want to drive the car right now. Then upgrade more later.
I'm also going to get another rear spring
I'll probably finish the front end. Guldstrand bushings and fix the bumpsteer. The gauge is 180 dollars though. Group purchase anyone? We can spread it around the corvette forum like the wheel stud fixture. After I use it first of course.
#44
#45
St. Jude Donor '07
I don't think they have a gauge. They didn't build their cars.
#46
ebaring, electric bearing?
the more backspace you can get, the bigger tire and wheel you can get under there. I don't want 10" fender flairs.
#47
The more backspace you have the less you have to flair.
P.S. Please keep irritating redvetracr. We'll get all of his secrets eventually.
#48
#50
just buy a wrecked vette zo6 and do a body swap from a c3...... shaaazzzzam..... a c3 with some *****
#51
St. Jude Donor '07
#52
When you get down to it, a C-6 is a C-3 updated.
It would be cheaper to turn a C-6 into a C-3 , than to turn a C-3 into a C-6.
#53
i did a pre-emptive post....
#54
St. Jude Donor '07
Although they may be flying by then
#55
There y go.
I wonder if I could start picking up all these totalled Enzo's. 3 or 4 might make a good car.
#57
#58
but using C1 and C2 bodies as they are more exclusive and justify the additional cost.
There's a '58 with a C5 chassis running a 502 big block I saw at the Melbourne 2004 Corvette convention,
and there's a 63 split window being mated to a ZO6 platform being built currently. An LS7 427 alloy small block is being fitted to that project.... Builder is also considering a S/C for a bit of additional boost for good measure. That car should be ready for next year's 2008 Aust Corvette convention in Adelaide.
It's the ONLY way to get modern driveability with the nostalgic beauty of early muscle cars. Crickey, even the latest offerings from GM and Ford, there so-called retro muscle cars... would be tame in comparison.
cheers
tom
#59
DRAG
Thats what threw me about the Bugatti Verion...it needs only 253 horsepower to reach 150 mph! That is awesome when you think about it. An average C3 might need 380-400hp to make that speed, and a prepared one 300 or so. The Bug needs the next 760 hp to go 100 mph faster, or 250 mph at 1000 hp. A comparable C-3??? The greenwood cars went very fast, but were racing machines. If you want an F50, just buy one.
I totally disagree with the above....I pulled 150 once with my top and windows down, the car was still pulling like a bandit, and lots to go, the front end was stable....by comparo to SOME cars, i'ts pretty much stock as a stove too...suspension wise....got 480-550? lbs springs in there with urethane bushings, but that' no big deal....I do have 17" Z rated rubber though or would never try that....I MAY have 375 hp outta that 355 engine with large TPI, maybe....but I was only about 1/2 throttle I feel the engine may have been putting out about 200 hp or so....
#60
I only have about 240 HP. I drove 120 MPH once, and had plenty of throttle left. Car drove steady and true, but when I started thinking about a flat tire, I was done for the day., back to 65.
