Distributor Breaker Plate
Old Apr 8, 2007 | 01:59 PM
SmokinBBC's Avatar
SmokinBBC
Default Distributor Breaker Plate
While I was tuning up my ride, I noticed that the dwell was jumping from 29-32 at all different RPMS and at idle. I thought my points were suspect, so I am replacing them...but the old points weren't that bad.
What I found was that my breaker plate has a lot of play. I could "wobble" it and see my point spring move. Is this my dwell problem?
My distr. shaft has very little end play. Do I need to shim up the breaker plate somehow?
If I recall, there was some kind of plastic/felt washer combo under it and possibly some kind of retainer. I rebuilt the dist. a while back and put in a new shaft due to a tack gear failure.
Old Apr 8, 2007 | 06:43 PM
69monzaredbigblock's Avatar
69monzaredbigblock
How does the upper shaft bushing in the distributor feel? If there is a lot of lateral play the bushing may need to be replaced. The upper bushing does not get lubed from engine oil, instead, it gets lube from grease packed in the upper cavity.
Old Apr 8, 2007 | 06:49 PM
SmokinBBC's Avatar
SmokinBBC
There is no lateral play in the shaft. I checked the bushing when I repaced the shaft. I also packed the upper cavity when I replaced the shaft.
The breaker plate seems to have too much play...like nothing is holding it in place. I think there may be a snap ring that holds the breaker plate in place. I'm wondering if the snap ring somehow broke.
Old Apr 8, 2007 | 06:50 PM
big_G's Avatar
big_G
Pull it apart. The lower bearing/bushing is probably egg-shaped also. Lots of load off the cam gear.
Old Apr 8, 2007 | 06:55 PM
Big2Bird's Avatar
Big2Bird
The breaker plate turns back and forth on this bushing on top of the housing. It is held on by a really small snap ring.
Excess clearance on this bushing would cause your (plate)wobble.
Old Apr 8, 2007 | 07:01 PM
SmokinBBC's Avatar
SmokinBBC
B2B. Thx. If there is too much clearance, do I have to replace the bushing? As I said previously, I have no lateral movement in the shaft.
I am hoping it is just a broken snap ring. When I rebuilt it, I am sure that the plate was tight.
Old Apr 8, 2007 | 07:10 PM
Big2Bird's Avatar
Big2Bird
I just measured the one I am rebuilding now. The plate is tight on the bushing. The bushing OD is .643. The plate ID is .645 Do you have a way to check yours?
Old Apr 8, 2007 | 07:14 PM
SmokinBBC's Avatar
SmokinBBC
Is the plate tight without the snap ring?
No way to check it on the car. I'm going to have to pull it and remove the shaft to check.
Old Apr 8, 2007 | 07:21 PM
Big2Bird's Avatar
Big2Bird
Yep. The snap ring keeps it stable vertically. See if it's there. It's small
Old Apr 8, 2007 | 07:24 PM
SmokinBBC's Avatar
SmokinBBC
Can't see it...probably to small
Time to pull it.
Thanks for the help!
PEPTO77's Avatar
PEPTO77
Hey smokinbbc, thanks for the input this weekend as the drama in my garage continued to elevate. I think I have my woes now narrowed to fuel delivery. Since you're talking about dwell, I've been staring at mine all weekend and it never wavers from 30*.
I appreciate the feedback. If you ever get over here to Concord I owe you a beer.
Old Apr 8, 2007 | 07:35 PM
SmokinBBC's Avatar
SmokinBBC
That's great...but I'd still recommend that you change out your 5 year old points
I get down to your area a couple of times a year for soccer tournaments for my son...next time, I'll look you up!
Old Apr 8, 2007 | 07:40 PM
PEPTO77's Avatar
PEPTO77
This weekend beat me up bad. I felt like I was runing through the woods with my eyes closed!
Points and condenser NEXT wekend.
Your beer's in the fridge.
Old Apr 8, 2007 | 07:44 PM
SmokinBBC's Avatar
SmokinBBC
Hopefully next weekend I'll have my Moving breaker plate mystery solved!
Old Apr 11, 2007 | 08:44 PM
SmokinBBC's Avatar
SmokinBBC
I pulled the dist.
The snap ring was in place but there was too much clearance between the top of the breaker plate and the snap ring. I tapped the bushing in slightly with my handy dandy bushing install tool and took out most of the play. Put on a new snap ring. It is snug now (no wobble) with enough play to allow the vac advance to move the plate without resistance.
I also shimmed it back to .005. It was close to .009. The bushings are perfect. The shaft has no vertical movement.
Put it back in and no more dramatic dwell fluctuation. sits at either 30 or 31 depending on revs..guess that's not bad. It is very stable at idle. I took it for a hard ride after resetting timing...runs very strong and smooth.
I'll have to keep an eye on it to see if it loosens up again. If it does, I guess the upper bushing may need to be replaced.
Old Apr 11, 2007 | 10:38 PM
Big2Bird's Avatar
Big2Bird
Shimming up th end play may save it. Excessive end play may have caused it.
To Distributor Breaker Plate
